Question about alignment of steering arm #152118
11/17/08 08:46 AM
11/17/08 08:46 AM
Danville, NH
Mopar_Mike Offline OP
Danville, NH
I am putting a new manual steering box into my 67 Coronet. I know the pitman arm can only go on the box one way, but at what position do you put it through the center link? Years ago I turned the wheels all the way one way and then the box all the way that way and then hooked it up. This did not work though as it was about a 60/40 turn ratio rather than a 50/50. Thanks.
RS23L7 4-Speed
Re: Question about alignment of steering arm [Re: Mopar_Mike] #152119
11/17/08 08:54 AM
11/17/08 08:54 AM
unless they have a different setup on 67 coronets, that connection to the centerlink is by a ball and socket type connection. the ball and stud will rotate in the socket on the pitman arm. so it doesnt need any special alignment
Re: Question about alignment of steering arm #152120
11/17/08 09:41 AM
11/17/08 09:41 AM
Danville, NH
Danville, NH
Actually it is different.. It is basically the same as inserting a ball joint through the center link.
RS23L7 4-Speed
Re: Question about alignment of steering arm #152121
11/17/08 10:25 AM
11/17/08 10:25 AM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
i would check the number of turns of the str.box lock to lock,stop in the center,set the wheels straight and hook the center link up.does this sound like what you are asking? ck. to see if you have same turns both ways before final tighting. you can center str. wheel later. this should work if str. box is all you are changing.
Re: Question about alignment of steering arm [Re: pushbutton] #152122
11/17/08 10:30 AM
11/17/08 10:30 AM
Danville, NH
Danville, NH
Yeah, I think that will do it. Thanks!
RS23L7 4-Speed
Re: Question about alignment of steering arm [Re: Mopar_Mike] #152123
11/17/08 10:59 AM
11/17/08 10:59 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
to fix that the tie rods would have had to been adjusted properly , the steering box needs to be centered FIRST , the pitman arm is keyed as is the steering column connection .
