Dakota rear axle bearings #1520954
10/21/13 11:09 AM
10/21/13 11:09 AM
Arlington, Texas
bobby66 Offline OP
bobby66  Offline OP
Arlington, Texas
Did some PM on my 2002 Dakota Sport this morning and noticed a lot of end play in both rear axles. I believe this is a c-clip type differential with ball bearings. How much play is "normal"? It will hit 160,000 miles next week, but it's had an easy life.
Re: Dakota rear axle bearings [Re: bobby66] #1520955
10/21/13 11:43 AM
10/21/13 11:43 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
C clip with "roller" bearings. Some endplay is normal in that style of rearend
I am truckless..
Re: Dakota rear axle bearings [Re: 340SHORTY] #1520956
10/21/13 12:01 PM
10/21/13 12:01 PM
Arlington, Texas
bobby66 Offline OP
bobby66  Offline OP
Arlington, Texas
Thanks. I didn't put an indicator on it yet. I keep the fluids changed, but sooner or later everthing wears out.
Re: Dakota rear axle bearings [Re: bobby66] #1520957
10/21/13 01:03 PM
10/21/13 01:03 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
There will be a considerable amount of end play as the only thing holding the axle in place is the C-clip that stops it from pulling out snd the center pin that holds it from pushing in
The bearings will be pressed into the axle tube and stay in place until pulled with a slide hammer. They are also lubricated with the same gear lube as the center diff, with the oil seal being outside of the wheel bearings.
As long as you don't have 'lateral' movement of the axle, (up/down, front/back) and it only goes in/out, then you're fine
**Photobucket sucks**
