Re: Dakota rear axle bearings
[Re: bobby66]
#1520955
10/21/13 11:43 AM
10/21/13 11:43 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
C clip with "roller" bearings. Some endplay is normal in that style of rearend
I am truckless..
[Re: 340SHORTY]
#1520956
10/21/13 12:01 PM
10/21/13 12:01 PM
Posts: 3,809 Arlington, Texas
bobby66
Arlington, Texas
Thanks. I didn't put an indicator on it yet. I keep the fluids changed, but sooner or later everthing wears out.
[Re: bobby66]
#1520957
10/21/13 01:03 PM
10/21/13 01:03 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
There will be a considerable amount of end play as the only thing holding the axle in place is the C-clip that stops it from pulling out snd the center pin that holds it from pushing in
The bearings will be pressed into the axle tube and stay in place until pulled with a slide hammer. They are also lubricated with the same gear lube as the center diff, with the oil seal being outside of the wheel bearings.
As long as you don't have 'lateral' movement of the axle, (up/down, front/back) and it only goes in/out, then you're fine
**Photobucket sucks**
