Does anyone use Caltracs 90/10 shocks? #1520927
10/21/13 11:05 AM
10/21/13 11:05 AM
Mohnton, Pa
DodgeCharger Offline OP
Mohnton, Pa
Still can't get my car to hook. The track was bad this weekend at Maple Grove and it showed me were my problems are with suspension.
I am running QA1 single adjustable front shocks. I thought they were ok. My car starts to pull the front tires about 3 inches then the front drops right back down. I tried lifting the nose of the car and it is stiff. But if you unhook the shocks the nose comes right up. I took the shock out of the car. If I pull them apart slow they have little resistance but if I try to pull them apart fast they are like a 50/50 stiff shock.
My question is do the Caltrac shocks work. Do they separate fast? I would run the car without shocks but I don't want to have the front end come crashing down.
I am running 325x50x15 mickey Thompson drag radials so I need maximum transfer to 60 ft. I'm not even close on a cold track.
Re: Does anyone use Caltracs 90/10 shocks? [Re: DodgeCharger] #1520928
10/21/13 11:32 AM
10/21/13 11:32 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I use them and they are good, they separate easy but dont unnerve the car down track. Although one or two people on here, said they affected their car's handling.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Does anyone use Caltracs 90/10 shocks? [Re: deaks] #1520929
10/21/13 11:50 AM
10/21/13 11:50 AM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
They work good for me.
Re: Does anyone use Caltracs 90/10 shocks? [Re: DodgeCharger] #1520930
10/21/13 12:10 PM
10/21/13 12:10 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
I have some CE 90/10 front shocks if you want to try them. But keep in mind you don't want the front to come up to quickly though...
Re: Does anyone use Caltracs 90/10 shocks? [Re: TheOtherDodge] #1520931
10/21/13 12:24 PM
10/21/13 12:24 PM
Ft. Wayne, IN.
Q
QTR MILR Offline
QTR MILR  Offline
Q
Ft. Wayne, IN.
I use them on my Satellite. I love them. I have no handling issues. I drive them on the street also. Do you have at least 5 inches of travel in the front?? I cut down the front bumpstops to get a little more movement.
Scott
69 Satellite, 3650lb street car... Dunnuck Racing pump gas 440. Best of 10:60@127...
Re: Does anyone use Caltracs 90/10 shocks? [Re: QTR MILR] #1520932
10/21/13 01:40 PM
10/21/13 01:40 PM
Mohnton, Pa
Mohnton, Pa
Yes I have a little over 5 inches of travel. The front is just to stiff with the QA1 shocks.
Re: Does anyone use Caltracs 90/10 shocks? [Re: QTR MILR] #1520933
10/21/13 01:41 PM
10/21/13 01:41 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
As caltrac says great for 9.90 and slower cars. Loved them on my car before the afcos. Lots of street driving with out a problem.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Does anyone use Caltracs 90/10 shocks? [Re: 1967dartgt] #1520934
10/21/13 01:53 PM
10/21/13 01:53 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
Yes, they are very loose, and work well. For what its worth, my car ran the same with CE 90/10 shocks...no difference at all.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Does anyone use Caltracs 90/10 shocks? [Re: FlyFish] #1520935
10/21/13 03:21 PM
10/21/13 03:21 PM
Elverson, Pa
Joe Grippo Offline
Joe Grippo  Offline
Elverson, Pa
They work great, too great for me as they were sending my car to the moon. I switched back to the CE's set at 80/20 and have been very consistent. Nice wheels up launch, nice carry and an easy landing. I was 1.399 & 1.401 on the two runs Saturday (left lane, right lane respectively).
Good seeing you again, are you coming back this Sunday?
Re: Does anyone use Caltracs 90/10 shocks? [Re: Joe Grippo] #1520936
10/21/13 04:52 PM
10/21/13 04:52 PM
Mohnton, Pa
Mohnton, Pa
It was good seeing you. How far did you go? I red lighted -.025 first round. If I get my car switched around I plan on going on Sunday. I figure if I get this thing working decent with the cold track it will only hook better in the summer. You have your car working. I wish I could get mine to work half that good. I watched your in car video on youtube. I don't know if I would want to look at the sky as long as you do every run.
Re: Does anyone use Caltracs 90/10 shocks? [Re: DodgeCharger] #1520937
10/21/13 05:16 PM
10/21/13 05:16 PM
fullmetaljacket Offline
Cal 90/10's work great for me and tons of street driving.
Re: Does anyone use Caltracs 90/10 shocks? [Re: DodgeCharger] #1520938
10/21/13 09:39 PM
10/21/13 09:39 PM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
Yes, I just took off my QA1 SA and put on an older set of caltrac 90/10s. a BIG change Wheels off on launch, 2nd & 3rd
It really needs double adjustables to settle it down. The QA1s just did not want to compress and I don't think it was settling down.
amazing how much of an effect front shocks have
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: Does anyone use Caltracs 90/10 shocks? [Re: oldiron] #1520939
10/21/13 09:52 PM
10/21/13 09:52 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
yup I have them.
time for some DA on the front for me .
Re: Does anyone use Caltracs 90/10 shocks? [Re: a493demon] #1520940
10/22/13 12:57 AM
10/22/13 12:57 AM
fresno ca
mikeysmopars Offline
fresno ca
They helped me... as previously said should be good for 9.90 cars or slower.And they do come up fast and hold it there.
Founder and CEO of the Central Valley Mopar Drag Pack
Re: Does anyone use Caltracs 90/10 shocks? [Re: oldiron] #1520941
10/22/13 02:25 AM
10/22/13 02:25 AM
sweden
sshemi Offline
sshemi  Offline
sweden
Sorry to be off topic but man i love that car!
Re: Does anyone use Caltracs 90/10 shocks? [Re: DodgeCharger] #1520942
10/22/13 10:06 AM
10/22/13 10:06 AM
an8sec70cuda Offline
They did not work at all on my car. Lifted too easily and would unload the rear. Works great w/ a stiffer shock.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Does anyone use Caltracs 90/10 shocks? [Re: an8sec70cuda] #1520943
10/22/13 10:21 AM
10/22/13 10:21 AM
I'm using HD pickup truck shocks out rear.
Re: Does anyone use Caltracs 90/10 shocks? [Re: DodgeCharger] #1520944
10/22/13 10:27 AM
10/22/13 10:27 AM
Mt Morris Michigan
mopar dave Online content
mopar dave  Online Content
Mt Morris Michigan
I use a calvert 90/10's as well. work good.
I chased my tail with the drag radials for a long time. couldn't get the car to 60' very well(1.52)and that was with the hoosier DR. went to hoosier QTP and 60'improved to 1.45-.47 and they last a lot longer than the DR's. I ran the M/T DR for a long time and found the hoosier worked better. DR are difficult getting the chassis set up. i'v seen some with DR have double adjustables on front and back and they pull timing on the launch. way more trouble than I wanted. switch over to the QTP and you'll be glad you did. I still street drive with mine and don't have to buy new tires every year.
Re: Does anyone use Caltracs 90/10 shocks? [Re: mopar dave] #1520945
10/22/13 10:42 AM
10/22/13 10:42 AM
same exact here. QTP's are good.
Re: Does anyone use Caltracs 90/10 shocks? [Re: an8sec70cuda] #1520946
10/22/13 12:18 PM
10/22/13 12:18 PM
Mohnton, Pa
Mohnton, Pa
Hi Chip,
Do you have any video with these shocks? When you say they lifted to easy do you mean you were pulling the tires to high or the car wouldn't pull the tires before it spun? My car only pulls the tires quick about 2-3 inches then the front end drops.
