I need input on a gen 2 Hemi build #1520812
10/20/13 10:52 PM
10/20/13 10:52 PM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
I am going to build/buy a gen 2 hemi this winter and am looking for ideas. I am looking for a combination to run 11 teens at 3700# so I can add some weight to run 11:50 in the heat I am starting from zero I have no Heni parts at all to start with would like to do it through the exhaust 3in TTi is on the car now let me know what you guys think this will be a street(very limited) strip more strip then street
Re: I need input on a gen 2 Hemi build [Re: biff426] #1520813
10/20/13 11:20 PM
10/20/13 11:20 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Sounds exactly what I accomplished. My 71 GTX weighed 4100 with me, but ran 10.80's. I used a 1999 472 block, 10.75 to 1. 650 solid roller. Indy-3 intake with a Dominator. I used the 440 TTI exhaust and bolted right up to the Hemi TTI headers. Mildly ported Mopar aluminum heads.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: I need input on a gen 2 Hemi build [Re: sunroofgtx] #1520814
10/21/13 11:00 AM
10/21/13 11:00 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
To get where you want to go I prefer the pump gas flat tappet 528. Ray Barton has built plenty of them. Up to 800 hp. Let them guide you thru your build.
2011 Drag Pak Challenger
Re: I need input on a gen 2 Hemi build [Re: biff426] #1520815
10/21/13 11:19 AM
10/21/13 11:19 AM
Mohnton, Pa
DodgeCharger Offline
Mohnton, Pa
Since your Deleware and close to Barton's shop I would just have him build you a motor and you can go watch it run on the dyno.
It won't take much of a hemi to reach your goal.
I've had many motors built over the years for cars and motor cycles. Ray was the first engine builder that didn't over promise and under deliver on the horsepower. I wanted 800 hp and the motor made 845 hp.
Re: I need input on a gen 2 Hemi build [Re: DodgeCharger] #1520816
10/21/13 11:36 AM
10/21/13 11:36 AM
Backwater, PA
bwdst6 Offline
Bob George Racing #1 Fan
bwdst6  Offline
Backwater, PA
As an FYI, his dyno will show hp numbers that are about 50 less than other engine dynos. So you would probably be showing around 900 hp on other dynos.
This post is available in double vision where drunk.
Re: I need input on a gen 2 Hemi build [Re: bwdst6] #1520817
10/21/13 12:06 PM
10/21/13 12:06 PM
Mohnton, Pa
Mohnton, Pa
I've had this motor for about 10 years and I've never been disappointed with its performance.
