440 cylinder wear #1520639
10/20/13 07:09 PM
10/20/13 07:09 PM
california
dragduster71 Offline OP
california
hello i have a 76 440 it was having bad bearing noises.all the rod bearings were brass on the rod side and not the cap side.it also had a broken ring. its already been rebuilt and bored 30 over.i would really like to just hone it and put new bearings and rings..i havent taken it it to the machine shop yet before i do id like some ideas from u guys first
Re: 440 cylinder wear [Re: dragduster71] #1520640
10/20/13 08:40 PM
10/20/13 08:40 PM
NEW HAMPSHIRE AND MAINE
BIGSTROKER Offline
BIGSTROKER  Offline
Looks like you need to turn the crank
Re: 440 cylinder wear [Re: dragduster71] #1520641
10/21/13 06:03 AM
10/21/13 06:03 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
I would be wondering what the ringlands on the pistons are like???
Re: 440 cylinder wear [Re: dragduster71] #1520642
10/21/13 11:50 AM
10/21/13 11:50 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Severe detonation caused that .
Re: 440 cylinder wear [Re: JohnRR] #1520643
10/21/13 11:55 AM
10/21/13 11:55 AM
CO
N
Nitrojunkee Offline
Nitrojunkee  Offline
N
CO
Yep, no doubt about that. Did the bearings come out of the rod ends and caps fairly easily as well? That would be another sign the bearings were getting hammered on. What do the rotors on the oil pump look like?
Re: 440 cylinder wear [Re: Nitrojunkee] #1520644
10/23/13 12:27 AM
10/23/13 12:27 AM
california
california
the rod caps took a few hits with a hammer on top to come apart,the engine was running pretty good,so i took off the manifolds and put headers on thats when the noises started.the engine is all dark brown inside like they never changed the oil?the center of the rods the color u see in the middle everything is that color in the bottem end
Re: 440 cylinder wear [Re: dragduster71] #1520645
10/23/13 12:45 AM
10/23/13 12:45 AM
california
california
more pics
Re: 440 cylinder wear [Re: dragduster71] #1520646
10/23/13 12:46 AM
10/23/13 12:46 AM
california
california
opps 1 at a time i guess
Re: 440 cylinder wear [Re: dragduster71] #1520647
10/23/13 12:47 AM
10/23/13 12:47 AM
california
california
another
Re: 440 cylinder wear [Re: dragduster71] #1520648
10/23/13 12:48 AM
10/23/13 12:48 AM
california
california
opps
Re: 440 cylinder wear [Re: dragduster71] #1520649
10/23/13 12:49 AM
10/23/13 12:49 AM
california
california
la
Re: 440 cylinder wear [Re: dragduster71] #1520650
10/25/13 12:34 AM
10/25/13 12:34 AM
california
california
im concidering using a flex hone ive seen cylinders worse then mine come out good
Re: 440 cylinder wear [Re: dragduster71] #1520651
10/25/13 12:48 AM
10/25/13 12:48 AM
california
california
im new at engine diagnostic what exactly is severe detonation?the truck passed ca smog easy and like a week later it just started making a scratching noise which was the rod bearings.
Re: 440 cylinder wear [Re: dragduster71] #1520652
10/25/13 12:51 AM
10/25/13 12:51 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Where in Cally r u?
Re: 440 cylinder wear [Re: Thumperdart] #1520653
10/25/13 01:12 PM
10/25/13 01:12 PM
california
california
visalia,ca
Re: 440 cylinder wear [Re: dragduster71] #1520654
10/25/13 01:38 PM
10/25/13 01:38 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What is severve detonation ... if you can HEAR it it's REALLY bad ...
Does it sound like a DIESEL when you have your foot in it ?
Re: 440 cylinder wear [Re: dragduster71] #1520655
10/25/13 01:44 PM
10/25/13 01:44 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
i'm new at engine diagnostic what exactly is severe detonation?
Research 'pre-ignition', and 'detonation'...
Re: 440 cylinder wear [Re: dragduster71] #1520656
10/25/13 01:47 PM
10/25/13 01:47 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
detonation is an explosion which is not what you want/need in a gasoline engine, what you want is a fast burn.
think of it this way it's the difference between pushing on something or punching it. if you were going shopping you would push the cart not punch it. detonation can be caused by many things or a combination of things and it will damage an engine if left uncorrected.
