1970 Road Runner horn issue #1520575
10/20/13 05:46 PM
10/20/13 05:46 PM
Indiana
mowch70 Offline OP
mowch70  Offline OP
Indiana
The horn works fine when the car is running, but when the car is off, it works about 20% of the time. Embarrassing when I'm at a show and someone wants to hear the horn and it won't work. Is the horn relay the issue?
Re: 1970 Road Runner horn issue [Re: mowch70] #1520576
10/20/13 06:02 PM
10/20/13 06:02 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
that's where i would start. if that doesn't solve it you'll have to bust out the volt meter and trace the power in both running and not running. what's the wiring like? original, repro, mess of splices and tape? have you ever taken the wheel off and looked at the horn switch? it could be the spot where you 'park' the steering wheel (70 was the first year for column mount locking wheel isn't it?. it could be worn or not making contact.
Re: 1970 Road Runner horn issue [Re: mikemee1331] #1520577
10/20/13 06:14 PM
10/20/13 06:14 PM
Indiana
mowch70 Offline OP
mowch70  Offline OP
Indiana
Wiring is original and in good shape. I've had the steering wheel off to replace the ignition switch and everything looked fine. I didn't think about the spot where the steering wheel "parks". I'll have to stop the car with wheels turned a little bit, and see if that changes things. I think it's the relay, but couldn't think of anything else. Thanks.
Re: 1970 Road Runner horn issue [Re: mowch70] #1520578
10/21/13 10:26 AM
10/21/13 10:26 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
By the way where is the relay on a 70. I know a 69 has it out by the horn. Guy in my club says in 70 it is under the dash?
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: 1970 Road Runner horn issue [Re: MOPARMIKE69] #1520579
10/21/13 10:52 AM
10/21/13 10:52 AM
What mike said, grab your meter & get after it when it ain't working to find the part time open. As you know wires in a circuit lose continuity at the terminals/ends & I'd check all of em & seperate the pull apart connector under the steering colume & ohm it to see if the problem is under the steering wheel. I would think that the relay is still on the firewall but you'd easily spot it if it is
Re: 1970 Road Runner horn issue [Re: mowch70] #1520580
10/21/13 12:14 PM
10/21/13 12:14 PM
USA
b54406barrel Offline
USA
Had that happen about 30 years ago. It was a little corrosion on the contacts right at the horn hub on the wheel. Relay is bolted to the underside of the bottom of the dash, between park brake handle & steering column.
Re: 1970 Road Runner horn issue [Re: b54406barrel] #1520581
10/21/13 04:25 PM
10/21/13 04:25 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
and i'm pretty sure 70 is the first year for a locking wheel which would put the contacts in the same spot everytime.
Re: 1970 Road Runner horn issue [Re: mikemee1331] #1520582
11/05/13 01:24 PM
11/05/13 01:24 PM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
Will a RR horn work without a relay? I want to put one on something that just a has a 12 volt wire going to it for the beep beep sound.
2011 Drag Pak Challenger
Re: 1970 Road Runner horn issue [Re: rickseeman] #1520583
11/05/13 01:58 PM
11/05/13 01:58 PM
If you used an add on momentary contact switch & wires of adequate gauge it'd work. The steering wheel contact, grounds the wire so there would not be a way for the steering wheel contact to open/close a hot 12V power in feed wire which the add on momentary contact switch would do. Not sure if that is what you are asking
Re: 1970 Road Runner horn issue [Re: RapidRobert] #1520584
11/06/13 02:16 AM
11/06/13 02:16 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
for it to go beep beep you need to push the button twice...LOL
I am truckless..
Re: 1970 Road Runner horn issue [Re: 340SHORTY] #1520585
11/06/13 02:44 AM
11/06/13 02:44 AM
Ding ding ding I do believe we have a winna
Re: 1970 Road Runner horn issue [Re: rickseeman] #1520586
11/06/13 11:28 AM
11/06/13 11:28 AM
You could run 12V to the horn with an inline fuse holder/20A fuse then mount the horn so it is insulated from the frame ground then run a ground wire from the horn case to the wire on the bulkhead coming from the st column that used to go to the horn relay. Or just sub in the RR horn instead of the OE horns & use the OE relay setup
