Correct 6BBL PCV Valve #1519705
10/18/13 06:41 PM
10/18/13 06:41 PM
NW Ohio
6pkaar Offline OP
6pkaar  Offline OP
NW Ohio
iIs there a differemce between the '70 340/6 and 440/6 PCV valve. I keep getting conflicting information.
Re: Correct 6BBL PCV Valve [Re: 6pkaar] #1519706
10/18/13 07:10 PM
10/18/13 07:10 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
both of these T/As have the wrong pcv valve....
http://www.ebay.com/itm/Dodge-Challenger...=US_Cars_Trucks
Re: Correct 6BBL PCV Valve [Re: Joesixpack] #1519707
10/18/13 07:11 PM
10/18/13 07:11 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
Re: Correct 6BBL PCV Valve [Re: 6pkaar] #1519708
10/18/13 08:28 PM
10/18/13 08:28 PM
1970_EK2AAR Offline
1970_EK2AAR  Offline
Small block and big block PCV valves are different from each other in 1970 . . . and in several other years as well.
Re: Correct 6BBL PCV Valve [Re: Joesixpack] #1519709
10/18/13 09:15 PM
10/18/13 09:15 PM
western australia
1cuda Offline
1cuda  Offline
western australia
wrong pcv #2
sorry to highjack the thread but am i wrong here...or is the guru wrong...http://my.autorevo.com/revo/Viewers/PopupViewer1.aspx?IID=4743767&PID=60621612
HRK5 on the tag and in the report...burnt orange leather interior?
my 440-6 cuda has PRT5 for tan leather...isn`t P the destination letter for leather?
my 71 has SRX9...S is leather for 71 cars.
either both of mine are wrong and the guru is correct...or i`ve got two factory issued tags that are wrong.
all the best
frank.
Re: Correct 6BBL PCV Valve [Re: 6pkaar] #1519710
10/18/13 11:33 PM
10/18/13 11:33 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
According to the 1970 parts book, all V8 engines use the same pcv valve. Part# listed is 3420224.
Re: Correct 6BBL PCV Valve [Re: 1cuda] #1519711
10/19/13 12:26 AM
10/19/13 12:26 AM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
...sorry to highjack the thread but am i wrong here...or is the guru wrong...http://my.autorevo.com/revo/Viewers/PopupViewer1.aspx?IID=4743767&PID=60621612
my 440-6 cuda has PRT5 for tan leather... isn`t P the destination letter for leather? my 71 has SRX9...S is leather for 71 cars.
all the best
frank.
Sorry to say, but yes, you are wrong. All of the codes you mention are correct. It is the 2nd digit, not the 1st, in the trim code which designates the material.
R = leather.
1970 trim codes from hamtramck historical;
1971 trim codes from hamtramck historical;
Re: Correct 6BBL PCV Valve [Re: moparfan53] #1519712
10/19/13 01:00 AM
10/19/13 01:00 AM
western australia
1cuda Offline
1cuda  Offline
western australia
R = leather.
thanx for the knowledge. i still don`t see a HRK5 in the charts you provided. was it a challenger only burnt orange leather thing?
all the best
frank.
Re: Correct 6BBL PCV Valve [Re: 1cuda] #1519713
10/20/13 08:27 AM
10/20/13 08:27 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
1970 PCV Valve, plastic upper body,3 ribbed design, metal base....
Re: Correct 6BBL PCV Valve [Re: Joesixpack] #1519714
10/20/13 08:31 AM
10/20/13 08:31 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
71 pcv valve, smooth upper plastic body, metal base.
Re: Correct 6BBL PCV Valve [Re: Joesixpack] #1519715
10/20/13 01:50 PM
10/20/13 01:50 PM
NW Ohio
6pkaar Offline OP
6pkaar  Offline OP
NW Ohio
Was this one ever used on '70 440's?
Re: Correct 6BBL PCV Valve [Re: 6pkaar] #1519716
10/20/13 02:13 PM
10/20/13 02:13 PM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
original untouched, these are off of a 70 U code cuda
Re: Correct 6BBL PCV Valve [Re: shakerjoe] #1519717
10/20/13 02:14 PM
10/20/13 02:14 PM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
second
Re: Correct 6BBL PCV Valve [Re: shakerjoe] #1519718
10/20/13 05:12 PM
10/20/13 05:12 PM
NW Ohio
6pkaar Offline OP
6pkaar  Offline OP
NW Ohio
Soooo..... 3 rib style on '70 340/6 and the '71 style on the '70 440/6?
Re: Correct 6BBL PCV Valve [Re: shakerjoe] #1519719
10/20/13 05:34 PM
10/20/13 05:34 PM
california
Mr D21 Offline
Mr D21  Offline
california
My all original 70 U code has the same PCV (except not painted)... I think its the same on all 70 motors,,, Can't imagine why there would be a difference whether it's SB or BB.
Re: Correct 6BBL PCV Valve [Re: 1cuda] #1519720
10/20/13 06:40 PM
10/20/13 06:40 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
It is HRK4 - see http://www.hamtramck-historical.com/images/dealerships/colorAndTrim/1970/70_Challenger0004.jpg
Challenger only.
Re: Correct 6BBL PCV Valve [Re: Alaskan_TA] #1519721
10/20/13 06:46 PM
10/20/13 06:46 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
far as i know smooth plastic body is 71, now it was the replacement pcv valve in 71 for all the 70s when they came in for tune ups...i have not had an original 70 to know if they were used in 70
Re: Correct 6BBL PCV Valve [Re: Mr D21] #1519722
10/20/13 07:23 PM
10/20/13 07:23 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Would originally be painted with assembled motor.
Some of these I've cleaned paint off of, and some are probably replacements. Some are smooth style, but molded in black plastic.
Re: Correct 6BBL PCV Valve [Re: autoxcuda] #1519723
10/20/13 08:36 PM
10/20/13 08:36 PM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
maybe there was a changeover date from ribbed to smooth barrel? The 70 v/c's I posted I know are oe and the car is still owned by the owner of the vc's with it's original motor. Here's a pic of a 70 440 that Frank Badalson had on display at Carlisle a few years ago - ribbed pcv
Re: Correct 6BBL PCV Valve [Re: shakerjoe] #1519724
10/20/13 08:38 PM
10/20/13 08:38 PM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
70 T/A local to me
