Page 4 of 9 1 2 3 4 5 6 7 8 9
Re: Borgeson Stering Box [Re: Tomswheels] #1519578
02/12/14 06:58 PM
02/12/14 06:58 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Perhaps I'm not describing it correctly, but with my Firm Feel stage 3 box occasionally, not every time, you will turn the steering wheel one inch and get nothing, then two inches, nothing, then as you turn the third inch you get 3 inches of input all at once. It ain't tires or a lack of stiffness in the car, it's the steering box. Since it doesn't do it every time, it can make the car a handful in quick transitions. I'm going Borgeson....
I somewhat recognize this behaviour, but are you really sure that comes from the steeringbox only?
I would think this has more to do with a wheel alignment or maybe a more likely worn idler arm bushing.
One car of mine sometimes shows this behaviour aswell, but I know the wheels aren't aligned properly, along with an old stock powersteering box.
Is the numbness only felt when turning the steeringwheel either to the left, or the right at that time?
If it's only happening at one direction, the linkage could just be busy taking up all the slack in the system first before the actual wheelmovement is happening.
You might be able to test this stationary by checking toe-settings while slightly turning the steeringwheel alternatly left and right, and compare both possible toe-setting differences.
Re: Borgeson Stering Box [Re: BigBlockMopar] #1519579
02/12/14 10:57 PM
02/12/14 10:57 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
Stiffening the k frame appears to be the foundation for steering control and repeatability and accurate outputs from a given input from the steering wheel.
The Borgeson box appears to be an improved box with a quicker ratio.
How many with a Borgeson box have a welded up k frame that is up to the same standards as Firm Feel does?
Re: Borgeson Stering Box [Re: PHJ426] #1519580
02/13/14 07:00 AM
02/13/14 07:00 AM
The Netherlands
The Netherlands
I still have a stock, unmodified K-member in my '73 Dart.
Since the K-member in my car has been powdercoated at one time, adding reinforcements while mounted in the car is a bit hard to do at the moment.
I do want to gusset the steeringbox mount but that will probably be when I'm ready to an engine swap in the car.
Re: Borgeson Stering Box [Re: BigBlockMopar] #1519581
02/16/14 03:27 PM
02/16/14 03:27 PM
Marion Illinois
72d100 Offline
72d100  Offline
Marion Illinois
i wonder if this can be made work for a truck
Re: Borgeson Stering Box [Re: 72d100] #1519582
02/16/14 04:10 PM
02/16/14 04:10 PM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
The Delphi steering box is common in circle track racing in various ratio's . Wonder why it is only available in the Mopar application in 14:1?
Re: Borgeson Stering Box [Re: brads70] #1519583
02/16/14 05:45 PM
02/16/14 05:45 PM
The Netherlands
The Netherlands
I wonder when the first C-body will pop up with a Borgbox under the hood...
Maybe Feets will be looking to improve the steering in his Imperial in time?
Re: Borgeson Stering Box [Re: BigBlockMopar] #1519584
02/16/14 06:14 PM
02/16/14 06:14 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Isn't an Imperial different than a C body?
Re: Borgeson Stering Box [Re: ThermoQuad] #1519585
02/16/14 06:47 PM
02/16/14 06:47 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I have the Firm Feel stage 3 on my 69 Barracuda, and it's good, except for the fact there is still some just off center numbness. For Autocrossing it's not ideal. I'm putting the Borgeson in my 67 Valiant because if it's anything like the newer Cherokee it came out of, it will be better...
Cars that are not reinforced in critical areas will exhibit the "off center numbness" regardless of whose steering box is in the car. The bigger the front tires - the more numbness you will experience under load.
I got the FF Stage 2 box and their sector support kit and I definitely have a gap of about 15 degrees on the steering from center left or right before the wheels start to move. I wonder if it is worse because of my steamroller tires? I must say it still feels a lot better than my steering from before!
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Borgeson Stering Box [Re: RylisPro] #1519586
02/16/14 08:32 PM
02/16/14 08:32 PM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
I have had the stage 3 FF box on for 3 years now. Never an issue yet? I'm about to install much wider rims/tires so maybe I'll notice an issue then?
My K-frame is all re-welded and gussets added for the steering box mount.
Re: Borgeson Stering Box [Re: moparpollack] #1519587
02/16/14 08:35 PM
02/16/14 08:35 PM
The Netherlands
The Netherlands
A lot of things are different on those cars but I don't think or see why they would have designed a different steeringbox for such a low production car line. But I'll probably be proven wrong...
Re: Borgeson Stering Box [Re: RylisPro] #1519588
02/16/14 10:21 PM
02/16/14 10:21 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I have a reinforced K member in the Charger, a FF #3 box, 275-40-18 front tires and there is a degree of looseness from 11:00 to 1:00 no matter the adjustment on the top of the steering chuck. This is what I have heard elsewhere. I don't blame the Firm Feel guys. I think that it is due to the actual design of the steering unit itself. It is because of this that I am curious about the Borgeson unit.
Re: Borgeson Stering Box [Re: Kern Dog] #1519589
02/17/14 12:54 AM
02/17/14 12:54 AM
Santa Fe Springs, CA
Dan@Hotchkis Offline
By making small mesh adjustments, I haven't had a Firm Feel rebuilt box that is any different from the Borgeson units. Any slop in the steering is induced by deflection in tires, components or alignments that cause steering center to be off.
FWIW, we have cars with both boxes, we sell neither, so we are about as unbiased as you can get. I just want you guys to have fast cars. If the Firm Feel guys say your box is toast, or you are converting to power form manual, then I would say that Bergman or Borgeson is the way to go. If you car is already a power car, save some coin and rebuilt and adjust what you have. And remember, the mesh is a fine tuning to a larger adjustment.
Re: Borgeson Stering Box [Re: moparpollack] #1519590
02/18/14 12:38 PM
02/18/14 12:38 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
It is different but the steering box is the same.
- Stu Harmon
Re: Borgeson Stering Box [Re: feets] #1519591
02/18/14 06:40 PM
02/18/14 06:40 PM
chicago il usa
K
komninon Offline
komninon  Offline
K
chicago il usa
we have ordered the borgeson box from bergman auto carft ,their coupler and hose kit. i took out my firmfeel III box with fast ratio pitman arm. hopefully we have it instaled soon , i will let you know if it is worth the money.
Re: Borgeson Stering Box [Re: Dan@Hotchkis] #1519592
02/18/14 06:42 PM
02/18/14 06:42 PM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
Sorry Dan, I have to disagree here...Cannot fight technology on this one....
Re: Borgeson Stering Box [Re: komninon] #1519593
02/20/14 02:44 AM
02/20/14 02:44 AM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
The way this winter is going your going to be test driving your car in May for that report....unless you want to drive it in this salty soupy mess out there.
Re: Borgeson Stering Box [Re: komninon] #1519594
02/20/14 09:55 AM
02/20/14 09:55 AM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
It will be good/helpful to hear what you find. I have to admit , I'm getting curious now....Just trying to wade through what is hype and what is fact? I have a fairly new FF stage 3 box so I'm in no hurry yet?
Re: Borgeson Stering Box [Re: komninon] #1519595
02/20/14 01:24 PM
02/20/14 01:24 PM
Washington State
cudaragtop Offline
cudaragtop  Offline
Washington State
Will you be trying the fast ratio arms with the Borg box? I'm interested in what the drivability is like with that combination.
Re: Borgeson Stering Box [Re: cudaragtop] #1519596
02/20/14 05:09 PM
02/20/14 05:09 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
I'm also interested to hear about the Borg'sn box WITH the fast-ratio longer arms (pitman and idler).... for steering response.
I initially also suspect the inside front tires will hit the frame rail more easily.
Aside from the newer technology of the Borg'sn box, in my opinion, the biggest advantage is the lighter weight of it as compared to a factory older ps box.... continuos reduced weight = faster lap times in every respect (accel, decel, cornering).
Re: Borgeson Stering Box [Re: cudaragtop] #1519597
02/20/14 05:12 PM
02/20/14 05:12 PM
chicago il usa
K
komninon Offline
komninon  Offline
K
chicago il usa
i will be using the stock pitman arm with the new box. c
