Re: Who to use for a legit fender tag? [Re: JohnRR] #1519197
10/18/13 02:38 PM
10/18/13 02:38 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
I tried a wire brush and it is so thin and crusty in a few spots I was making it worse. I'll keep the original and besides this is my 43rd mopar and I'm pushing 60 so this will be my last resto. I'll leave all the papers for my wifes next husband.
you took a wire brush to a thin and rusty fendertag ... are you crazy ???
Evaporust , soak it and then paint it . I would just leave the original tag on it ... assuming you didn't destroy it with the wire brush.
Like Scott said there is no legit tag... is the rest of the car so bad that a shiny new tag is going to make it look better ?
John,think Evaporust will work on this one ??
Re: Who to use for a legit fender tag? [Re: 62maxwgn] #1519198
10/18/13 03:14 PM
10/18/13 03:14 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
lots of flack and few answers to your question, its sad that this site has become like the H.A.M.B.
Re: Who to use for a legit fender tag? [Re: cmansell] #1519199
10/18/13 03:18 PM
10/18/13 03:18 PM
tennessee
P
pushbutton Online content
pushbutton  Online Content
P
tennessee
Thanks, that's who I'll call. I knew them and gts but wanted to see if anyone new was out there with a good reputation.
You could make a picture of your old rusty original tag and tape it to your inner fender next to your repo tag when you show your car to show the experts that your not trying to fool anyone. I can't blame anyone for not wanting to use a old rusty tag on a fresh restoration.
Re: Who to use for a legit fender tag? [Re: cmansell] #1519200
10/18/13 04:26 PM
10/18/13 04:26 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
www.datatags.com should be able to supply your needs, your just making a copy of your existing fender tag, so there should be no mistakes made as to lay out/codes, assuming the factory made no mistakes on the tag....if there's any special inspection marks/stamps on your tag, that AG. Backeast (Datatags) can't reproduce, there are sources for procuring custom made inspection stamps/marks, PM me if you need that information
Mike
FYI...in the future make your requests for imformation regarding VIN/fender tags/build sheets/etc/etc/etc brief and to the point to avoid the usual diaper fires it sets off on a few individuals, that way you avoid the that usually accompanies these posts
Re: Who to use for a legit fender tag? [Re: 65rbdodge] #1519201
10/18/13 04:27 PM
10/18/13 04:27 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
 a lot of flack and few answers to your question, its sad that this site has become like the H.A.M.B.
Hey, the question was answered in my first reply. Had he asked for a good source for a reproduction tag Id have answered it a bit differently. There's nothing wrong with owning or displaying a repro tag if you have the original for backup, but when you start thinking that its in any way "legit" or ok to change options (ANY options, tires in his case) the word fraud comes to mind.
Re: Who to use for a legit fender tag? [Re: ScottSmith_Harms] #1519202
10/18/13 04:36 PM
10/18/13 04:36 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I "interpreted" his post regarding the tires, as meaning his car is eactly as the fender tag indicates, WITH the exception of the tire size currenty ON the car (physicaly) with no indication or "hint" that he wanted a tag with a different tire size noted...
We need a TocoBell smiley for some who need to "think outside the bun"...
Re: Who to use for a legit fender tag? [Re: DAYCLONA] #1519203
10/18/13 04:49 PM
10/18/13 04:49 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Not a surprising post from a guy who fakes everything he touches
Re: Who to use for a legit fender tag? [Re: ScottSmith_Harms] #1519204
10/18/13 06:10 PM
10/18/13 06:10 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Why Thank You!...IIRC it was Enzo Ferrari that once said "Imitation is the sincerest form of flattery, esp when done well"...
Re: Who to use for a legit fender tag? [Re: DAYCLONA] #1519205
10/18/13 06:16 PM
10/18/13 06:16 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Ok "Enzo" good luck with that!
Re: Who to use for a legit fender tag? [Re: DAYCLONA] #1519206
10/18/13 06:17 PM
10/18/13 06:17 PM
california
Mr D21 Offline
Mr D21  Offline
california
Imitation and forgery are not the same thing...
Re: Who to use for a legit fender tag? [Re: Mr D21] #1519207
10/18/13 06:27 PM
10/18/13 06:27 PM
cmansell Offline OP
cmansell  Offline OP
The tag will stay the same, my car has 15's now and other than that it still matches the tag if you don't count the pertronix.
Re: Who to use for a legit fender tag? [Re: ScottSmith_Harms] #1519208
10/18/13 06:35 PM
10/18/13 06:35 PM
NW Ohio
6pkaar Offline
6pkaar  Offline
NW Ohio
I'd like to tuck my original away in a safe place, but also want the tag on the car. This is the first I've seen a response like this! So, is it OK to have a repop on the car as long as it has 100% the same info on the tag the original one has as long as you have the original tag in a safe place? I've wanted to do this, but I also want to keep living!!
Re: Who to use for a legit fender tag? [Re: 62maxwgn] #1519209
10/18/13 08:08 PM
10/18/13 08:08 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
i have a tag that i'm afraid to put in evapo
Re: Who to use for a legit fender tag? [Re: 6pkaar] #1519210
10/18/13 08:33 PM
10/18/13 08:33 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
It really depends on personal opinion. My take is as long as the original is still with the car (or stored separately, etc. but stays with the car) and the reproduction is an identical duplicate, I don't see a problem with it. There are several sources for reproduction tags, some are definitely a lot closer than others but NONE of them are undetectable PERIOD! so while fraudulent builders might fool some of us, they can't fool all of us.
Re: Who to use for a legit fender tag? [Re: ScottSmith_Harms] #1519211
10/18/13 09:35 PM
10/18/13 09:35 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Probably easier to take it off and claim it was stolen than go through this.
Re: Who to use for a legit fender tag? [Re: 6PakBee] #1519212
10/18/13 11:28 PM
10/18/13 11:28 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
http://www.hemmings.com/mus/stories/2011/01/01/hmn_opinion4.html WANTED: 160 lbs of 1970 factory air, for a 71 e-body tire set with spare!!
Re: Who to use for a legit fender tag? [Re: 6PakBee] #1519213
10/19/13 12:38 AM
10/19/13 12:38 AM
michigan woods
imfixinmopars426 Offline
michigan woods
or. .better yet,install totally different tag...1972 polara wagon...that will piss them off
Re: Who to use for a legit fender tag? [Re: Jim_Lusk] #1519214
10/19/13 08:30 PM
10/19/13 08:30 PM
NY NY
3
340duster340 Offline
NY NY
Here's a made tag that I really like (the one on the right, the other is the original):
that is actually really cool. i am going to have a bogus tag like that made for my 66 dart rustoration.
