OD trans.swap question #151896
11/16/08 07:29 PM
11/16/08 07:29 PM
wi.
Rosco Offline OP
Rosco  Offline OP
wi.
What's needed when switching from an A833 to an overdrive 833?
Re: OD trans.swap question [Re: Rosco] #151897
11/16/08 08:29 PM
11/16/08 08:29 PM
upstate NY
batt2rm Offline
batt2rm  Offline
upstate NY
Nothing is needed other than the 3/4 shift level needs to be reversed 180 degrees. The linkage arm may need to be lengthened. The only other issue may be the size of the input shaft bearing retainer. If memory serves me the OD retainer is about 5.16" in diameter. You may have a 4.80 or smaller depending on your tranny. You may be able to use the input retainer from your 833.
Re: OD trans.swap question [Re: batt2rm] #151898
11/16/08 08:33 PM
11/16/08 08:33 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
that pretty much sums it up , BUT if you have a smallblock you will need to get a smallblock OD bellhousing , if a big block the reatiner for a big block 23 spline trans will bolt to the OD trans directly .
Re: OD trans.swap question [Re: JohnRR] #151899
11/16/08 09:00 PM
11/16/08 09:00 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
I think clutch forks on O.D. transmissions are longer than non-O.D. setups, but if you can get a matched O.D. BH (with the 5.125" bore hole) and clutch fork, do it.
Re: OD trans.swap question [Re: In_The_Pink] #151900
11/17/08 10:27 AM
11/17/08 10:27 AM
Mass
dgc333 Offline
dgc333  Offline
Mass
I am using a standard sb A-body clutch fork with an OD bellhousing and A833OD tranny. Works just fine.
Dave Clement Pembroke, MA 03 PT Cruiser GT Turbo 99 Dakota SLT+ CC 4x4 68 Barracuda sport coupe http://home.comcast.net/~dgc333/
