Firecore distributor set up... Opinions
#1518475
10/16/13 05:35 PM
10/16/13 05:35 PM
Posts: 4,732 Watertown, WI
MikeyT
Watertown, WI
Hi all,
I just picked up one of Rich's distributors and am really excited to run it, but I thought I would get some opinions on set up for tuning it for my street/strip set up.
72 road runner with 9:1 comp 440 915 heads with comp valvejob, lunati 303 cam and a edelbrock rpm intake, 750 DP Holley, 1 7/8 headers, 727 with 4:10 gears
1)Looking for recommendation on initial and total timing
2) at which RPM level should I have total timing in by (3000, 2500, etc)
3) which springs to use
Thanks all
Mikey
1969 Dodge Dart Swinger
Re: Firecore distributor set up... Opinions
[Re: MikeyT]
#1518478
10/16/13 07:45 PM
10/16/13 07:45 PM
RapidRobert
initial: with "vacuum gauge method". total: 36-38. springs: any combo that puts you just under the pinging point at WOT up thru the gears on your hottest/driest day no matter where (RPM) that makes the springs max out at. IN ORDER & if the vac gauge method when done makes the starter cranky when hot then reduce the initial timing 1 degree (not the in hg vac #) & repeat as needed (reducing it another 1 degree of timing if need be). EDIT then plug in/adj vac adv if used
[Re: QTR MILR]
#1518479
10/16/13 07:49 PM
10/16/13 07:49 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
I'd go with the lightest springs... I like to have my advance all in by 2000 at the latest. I'd shoot for 18-22 initial and somewhere around 38 total ( not including vac. advance). That's where my Satellite was when it was similar to your set-up. I run Ricks distributor and love it!!
This is a good range for initial that should work as a starting point. Find the point the where the starter kicksback as your initial limit and start tuning it up.
[Re: RobX4406]
#1518480
10/16/13 08:05 PM
10/16/13 08:05 PM
MikeyT
Watertown, WI
Thanks guys!
I appreciate the help
Mike
[Re: MikeyT]
#1518481
10/16/13 09:34 PM
10/16/13 09:34 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
I have a Firecore50 distributor in my car and all I had to do is adjust my total advance.I would leave the springs alone for your combination Just find out what your engine wants for base timing with a vacuum gauge then set your total at 2200. With the original springs I have my total timing all in by 2200 which works well for my car. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Dunnuck Racing]
#1518483
10/17/13 12:44 AM
10/17/13 12:44 AM
MikeyT
Watertown, WI
Ok, I am looking it over and have no instructions... Which is the lightest spring?
Mike
[Re: MikeyT]
#1518484
10/17/13 07:53 PM
10/17/13 07:53 PM
MikeyT
Watertown, WI
Bump
Which is which folks?
#1518486
10/18/13 01:30 AM
10/18/13 01:30 AM
MikeyT
Watertown, WI
Thanks, I believe your brother helped me out!
Mike
