Best exhaust manifold gaskets #1518327
10/16/13 08:40 AM
10/16/13 08:40 AM
Lakeland FL
floridian Offline OP
Lakeland FL
Any suggestions on the best exhaust manifold gaskets for a 440 using stock exhaust manifolds?? And where to purchase them?
thanks
Re: Best exhaust manifold gaskets [Re: floridian] #1518328
10/16/13 08:42 AM
10/16/13 08:42 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
The best is none, mill the manifolds flat and put them on.
Re: Best exhaust manifold gaskets [Re: floridian] #1518329
10/16/13 09:44 AM
10/16/13 09:44 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Mr Gasket ultra. Should be available through your local O'Reillys etc.
Re: Best exhaust manifold gaskets [Re: scatpacktom] #1518330
10/16/13 10:03 AM
10/16/13 10:03 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
This is how the factory installed them originally.
Now I will have the manifolds milled flat , they are ALL warped ... except maybe NOS ... and use the gasket that comes in the fel pro gasket set.
Re: Best exhaust manifold gaskets [Re: floridian] #1518331
10/16/13 07:47 PM
10/16/13 07:47 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
thanks
Remflex! www.remflex.com These are great gaskets.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Best exhaust manifold gaskets [Re: Junky] #1518332
10/16/13 07:48 PM
10/16/13 07:48 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
thanks
+1 for RemFlex
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Best exhaust manifold gaskets [Re: Pyper70] #1518333
10/17/13 12:18 AM
10/17/13 12:18 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I've good luck with the Ulta seals,but I will be trying the Super performance line of gaskets next go-round
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Best exhaust manifold gaskets [Re: hemi-itis] #1518334
10/17/13 10:46 AM
10/17/13 10:46 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
what ever gasket you chose to run the key is having a clean FLAT surface to seal against. Put the manifold down on a clean flat surface , use your kitchen counter when the wife isn't around, and look at it , the center 2 ports are probably not even touching the counter.
Re: Best exhaust manifold gaskets [Re: floridian] #1518335
10/17/13 01:26 PM
10/17/13 01:26 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Remflex work excellent. I can help you with them. I like the MR G Ultra Seals as well, but not as forgiving as the Remflex, but still a good gasket.
RIP Monte Smith
Re: Best exhaust manifold gaskets [Re: floridian] #1518336
10/17/13 05:29 PM
10/17/13 05:29 PM
Chicago illinois
ChinooK440 Offline
ChinooK440  Offline
Chicago illinois
The port size on Most performance or header gaskets are substantially larger the the stock port sizes in the heads and manifolds.
look at a Mr. G ultra seal on a stock port big block head . With manifolds there,s very little sealing surface in a few areas with these gaskets.....
Re: Best exhaust manifold gaskets [Re: JohnRR] #1518337
10/18/13 08:44 AM
10/18/13 08:44 AM
Lakeland FL
Lakeland FL
Thanks to all for the replys..
I had the manifolds surfaced when I restored the car, so I know they "were" flat.. Car is still in Oregon ( I now live in Florida). Drove it when on vacation back "home" and developed an exhaust leak. Tried to just loosen manifold and pull out the gasket, then retighten the manifold.. Lets just say it didn't work.. Hated to leave my car "broken" when I flew back to Florida..
I thought about not using gaskets when assembled but chose to use them.. Will try some remflex next time "home"... Need to get it running to load on transport to Florida...
Rick
Re: Best exhaust manifold gaskets [Re: floridian] #1518338
10/18/13 11:48 AM
10/18/13 11:48 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
The 1978 cop E86 (440) ones were great - thy had a built-in heat shield to prevent toasted valve cover gaskets.
I may have a few spares...
Rick
