Strange VIN Stamping - '70 'cuda 340 Trans Re-stamp? #1518249
10/15/13 10:11 PM
10/15/13 10:11 PM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
I am restoring a '70 cuda 340 4 speed with a SPD of 2/26. I had always thought the trans was a matching assy but now I am not so sure. Take a look at this VIN Stamping. I had thought the fonts and size looked normal and I have seen some pretty crappy VIN stampings on both blocks and tranny's but until I looked closer this trans appears to have a different story.
For all practical purposes, this trans looked to be the original assy for this car. It has the correct 696 blue stencil on the housing. The assy date of the Trans is Jan 13, 1970 which is kind of early for MY SPD. My VIN is OB262398 but the VIN underneath looks to be OB253550. Is it possible that it is a factory screwup? Like I said ... all indications are that the trans is original to the car.
The stamp looks old and pretty close to factory font... in the '3' and '2'.
I know what most will think but am wondering if somehow the trans was mis ID'd at the factory and then overstamped with my cars VIN. Perhaps the other VIN had already been used? and was duplicated in error on this trans. Anyone ever heard of anything like that happening?
Thoughts?
Re: Strange VIN Stamping - '70 'cuda 340 Trans Re-stamp? [Re: 70mopes] #1518250
10/15/13 10:13 PM
10/15/13 10:13 PM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
Another pic of trans after cleaning tonight
Re: Strange VIN Stamping - '70 'cuda 340 Trans Re-stamp? [Re: 70mopes] #1518251
10/15/13 10:14 PM
10/15/13 10:14 PM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
Another
Re: Strange VIN Stamping - '70 'cuda 340 Trans Re-stamp? [Re: 70mopes] #1518252
10/15/13 10:25 PM
10/15/13 10:25 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Post a good pic of your engines stamping
Re: Strange VIN Stamping - '70 'cuda 340 Trans Re-stamp? [Re: ScottSmith_Harms] #1518253
10/15/13 10:45 PM
10/15/13 10:45 PM
Az
69hemibeep Online content
69hemibeep  Online Content
Az
The engine and trans were bolted together before stamping
1969 Hemi Roadrunner 2nd owner
Re: Strange VIN Stamping - '70 'cuda 340 Trans Re-stamp? [Re: 69hemibeep] #1518254
10/15/13 11:02 PM
10/15/13 11:02 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
True but what if there was a small issue with the trans after it was already in the other VIN car then fixed and reused?
JB Rhinehart, Realist
A-Body's RULE!
Re: Strange VIN Stamping - '70 'cuda 340 Trans Re-stamp? [Re: 70mopes] #1518255
10/15/13 11:04 PM
10/15/13 11:04 PM
KS.
HairOtheDog Offline
HairOtheDog  Offline
KS.
I hate to say this, but I'm sure you suspect it;
But it looks like someone took a set of stamps to it, particularly at the beginning around the "OB2" where it was restamped over and over and over again, it looks like its been redone 5 or 6 times, its highly suspect. Also the depth on those stamps are really deep and heavy, compared to the original average stamps with 30+ years of age on them. Unfortunately, that doesn't look like a factory restamp to me.
Re: Strange VIN Stamping - '70 'cuda 340 Trans Re-stamp? [Re: HairOtheDog] #1518256
10/15/13 11:49 PM
10/15/13 11:49 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Both fonts are factory, but like Scott, I would like to see your engine stamping also.
Re: Strange VIN Stamping - '70 'cuda 340 Trans Re-stamp? [Re: 70mopes] #1518257
10/15/13 11:56 PM
10/15/13 11:56 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
That ones pretty obvious...yes, a restamp, but not factory done, I've been reproing fender tags, and other assorted tags, restamping blocks and transmissions, carbs, etc, etc for quite a few decades, most trying to re-stamp a casting, overly concern themselves with the font size, and shape, trying to match the factory "style",...but what the novice misses, or is not aware of is the "cut" of the stamp itself,...the factory (Chrysler in this case) always used "Sharp Faced" punch sets, even on "soft" castings like carbs,...the person that re-stamped this, while doing a decent job in font match, blew it by using a "Flat Faced" punch set, which is intended for aluminum or brass, etc, etc...that's the reason for the heavy "strike(s)", after the first blow, they realized the error, and decided to continue, albeit, a little heavy handed though... a Flat Face punch on cast iron is like using a butter knife to carve granite, even if they struck the pad clean, they blew it with the wrong punch face
Re: Strange VIN Stamping - '70 'cuda 340 Trans Re-stamp? [Re: DAYCLONA] #1518258
10/16/13 12:14 AM
10/16/13 12:14 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I would think even at the factory if they restamped something they would use a very heavy strike and probably quite a few times to make sure the numbers would be seen clearly. Even "sharp faced" stamps hit repeatedly would bounce around and make it look like a "flat faced" stamp...
A-Body's RULE!
Re: Strange VIN Stamping - '70 'cuda 340 Trans Re-stamp? [Re: Rhinodart] #1518259
10/16/13 12:59 AM
10/16/13 12:59 AM
KS.
HairOtheDog Offline
HairOtheDog  Offline
KS.
True,
But being cast iron, even IF the punch "bounced", it wouldn't bounce 5 or 6 times, and the bounce wouldn't be enough to make that heavy of a strike, repeatedly.
if it was aluminum?, sure, but not cast iron or steel.
Factory font? Yes,
but that's where the similarities end.
I know you're hoping for all factory, #'s matching, but the fact that you're asking, you already suspect that it isn't.
Heck, I'm no expert, so, maybe I'm wrong and I hope I am, but....
Re: Strange VIN Stamping - '70 'cuda 340 Trans Re-stamp? [Re: HairOtheDog] #1518260
10/16/13 01:07 AM
10/16/13 01:07 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Nice!
Re: Strange VIN Stamping - '70 'cuda 340 Trans Re-stamp? [Re: HairOtheDog] #1518261
10/16/13 01:19 AM
10/16/13 01:19 AM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
It's a pretty cool old cuda. It has been apart for ten years and prior to that had seen a pretty tough life. Like I said, this trans was nasty and had dirt stuck to it collected while Nixon was still in office. The original block was history when I got the car. It had a '68 block in it. I do not know what happened to the original... grenaded or broken somehow. Prior to me owning this car it was in thrashed, survivor condition having been through a shot to the front of it that required a lot of work to correct. I would be willing to say that it was never in a state that would drive a previous owner to screw with the numbers. No indication on this car show that it was ever treated anything other than harshly. It had the '68 340 block for a good long time. Like I said, the car had never been treated well. Not well enough to warrant going to this extent. It just does not add up for this car.
Re: Strange VIN Stamping - '70 'cuda 340 Trans Re-stamp? [Re: ScottSmith_Harms] #1518262
10/16/13 01:24 AM
10/16/13 01:24 AM
KY USA
mopargem Offline
mopargem  Offline
KY USA
look at the top of the 3,6 & 9. I believe a sharp faced punch was used
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F6 M6W
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: Strange VIN Stamping - '70 'cuda 340 Trans Re-stamp? [Re: mopargem] #1518263
10/16/13 01:28 AM
10/16/13 01:28 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Based on what I can see I would agree with Barry, that looks like a factory stamping. I can't explain WHY it was re-stamped, but there are various reasons why it COULD be original.
Re: Strange VIN Stamping - '70 'cuda 340 Trans Re-stamp? *DELETED* [Re: ScottSmith_Harms] #1518264
10/16/13 01:34 AM
10/16/13 01:34 AM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
Post deleted by 70mopes
Re: Strange VIN Stamping - '70 'cuda 340 Trans Re-stamp? [Re: 70mopes] #1518265
10/16/13 01:43 AM
10/16/13 01:43 AM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
RhinoDart brings up a good point of the trans having been in another car, perhaps had an issue and was yanked, fixed and re-installed in this car. I have seen a number of '70 4 speed transmissions markings but have not seen a white X or the large part number stamped in more than one place - or on top. Come to think of it, the shift plate did not have any paint markings on it which most do... wonder if that might have been a problem that needed correcting???
Re: Strange VIN Stamping - '70 'cuda 340 Trans Re-stamp? [Re: 70mopes] #1518266
10/16/13 01:44 AM
10/16/13 01:44 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
It would have been a Challenger.
Both cars were likely scheduled for a mid-February build, but there is no way to know when either was actually built.
The engines & transmissions were stamped right before the matching body was lowered onto them.
These two cars may have been one right after the other on the assembly line & the worker doing the stamps simply neglected to roll the digits to the correct numbers the first time.
We may never know for sure, but I do not see any evidence of fraud on this one.
Re: Strange VIN Stamping - '70 'cuda 340 Trans Re-stamp? [Re: Alaskan_TA] #1518267
10/16/13 02:11 AM
10/16/13 02:11 AM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
Good stuff Barry and Co. I have had this trans sitting on a dolly for years and had looked at the VIN many times... granted my eyesight is not what it once was but it always looked to me like it does in this picture which looked good to me. I didn't even notice the lighter understamping until I took a close up and downloaded the pic tonight. Man, this hobby never fails to amaze!
Re: Strange VIN Stamping - '70 'cuda 340 Trans Re-stamp? [Re: 70mopes] #1518268
10/16/13 02:33 AM
10/16/13 02:33 AM
the Netherlands
Mr4Speed Offline
Mr4Speed  Offline
the Netherlands
a friend of mine has a 69 roadrunner, matching numbers; tranny has never been out of the car; the numbers on his transmission look similar. I will try to post a pic later today.
