Re: Strange VIN Stamping - '70 'cuda 340 Trans Re-stamp?
[Re: 70mopes]
#1518257
10/15/13 11:56 PM
10/15/13 11:56 PM
Posts: 18,157 Mass
DAYCLONA
Mass
That ones pretty obvious...yes, a restamp, but not factory done, I've been reproing fender tags, and other assorted tags, restamping blocks and transmissions, carbs, etc, etc for quite a few decades, most trying to re-stamp a casting, overly concern themselves with the font size, and shape, trying to match the factory "style",...but what the novice misses, or is not aware of is the "cut" of the stamp itself,...the factory (Chrysler in this case) always used "Sharp Faced" punch sets, even on "soft" castings like carbs,...the person that re-stamped this, while doing a decent job in font match, blew it by using a "Flat Faced" punch set, which is intended for aluminum or brass, etc, etc...that's the reason for the heavy "strike(s)", after the first blow, they realized the error, and decided to continue, albeit, a little heavy handed though... a Flat Face punch on cast iron is like using a butter knife to carve granite, even if they struck the pad clean, they blew it with the wrong punch face
[Re: Rhinodart]
#1518259
10/16/13 12:59 AM
10/16/13 12:59 AM
Posts: 88 KS.
HairOtheDog
KS.
True, But being cast iron, even IF the punch "bounced", it wouldn't bounce 5 or 6 times, and the bounce wouldn't be enough to make that heavy of a strike, repeatedly. if it was aluminum?, sure, but not cast iron or steel. Factory font? Yes, but that's where the similarities end.
I know you're hoping for all factory, #'s matching, but the fact that you're asking, you already suspect that it isn't.
Heck, I'm no expert, so, maybe I'm wrong and I hope I am, but....
[Re: HairOtheDog]
#1518260
10/16/13 01:07 AM
10/16/13 01:07 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Nice!
[Re: ScottSmith_Harms]
#1518262
10/16/13 01:24 AM
10/16/13 01:24 AM
Posts: 3,378 KY USA
mopargem
KY USA
look at the top of the 3,6 & 9. I believe a sharp faced punch was used
68 Polara 500...LL1 Y7 M6X 69 Hemi road runner...X9 X9 M6X 69 A12 road runner....R4 R4 M6X 69 ModTop FLORAL Super Bee...F 70 AAR 'cuda...EW1 EW1 H4X9 71 Duster 340...FJ6 V24 L6X9 71 road runner FC7 V1X M6X9 72 Rallye Charger B5 V1W 74 'cuda 360...KB5 V1X A6X9 08 SRT Challenger #234
