Re: Hemi Crankshaft Questions
[Re: TrWaters]
#1517948
10/15/13 05:02 PM
10/15/13 05:02 PM
Posts: 25,877 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Any journal can be repaired individually, I would chrome rather than weld if you can find somebody that hard chromes shafts.
[Re: TrWaters]
#1517950
10/15/13 05:38 PM
10/15/13 05:38 PM
Posts: 7,495 Minnesota
Hemi_Joel
Minnesota
The problem solvers involve a pressed on sleeve over the damage, right? THe flange would be in the way...
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: TrWaters]
#1517954
10/15/13 09:22 PM
10/15/13 09:22 PM
Posts: 75,047 U.S.S.A.
JohnRR
U.S.S.A.
50's hemi, yes. By problem solver, I am talking an undersized I.D. seal. These originally had rope seals, but some aftermarket rubber seals are made.
What about turning it down and having a knurl put back on and using a rope seal ?
[Re: TrWaters]
#1517956
10/15/13 09:56 PM
10/15/13 09:56 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Shaftech in Ohio, The crank shop, NY.
RIP Monte Smith
