Hemi Crankshaft Questions #1517947
10/15/13 04:51 PM
10/15/13 04:51 PM
Vermont
TrWaters Offline OP
TrWaters  Offline OP
Vermont
I have an early hemi crankshaft with a pitted rear main seal surface. Originally used a rope seal. Who would you recommend to weld and grind the seal area, and can it be done without having to regrind the rest of the crank?
Re: Hemi Crankshaft Questions [Re: TrWaters] #1517948
10/15/13 05:02 PM
10/15/13 05:02 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Any journal can be repaired individually, I would chrome rather than weld if you can find somebody that hard chromes shafts.
Re: Hemi Crankshaft Questions [Re: John_Kunkel] #1517949
10/15/13 05:36 PM
10/15/13 05:36 PM
Vermont
TrWaters Offline OP
TrWaters  Offline OP
Vermont
Is there such a thing as a "problem solver" small block Mopar rear seal? I could market that.
Re: Hemi Crankshaft Questions [Re: TrWaters] #1517950
10/15/13 05:38 PM
10/15/13 05:38 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
The problem solvers involve a pressed on sleeve over the damage, right? THe flange would be in the way...
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Hemi Crankshaft Questions [Re: TrWaters] #1517951
10/15/13 07:00 PM
10/15/13 07:00 PM
When you say early hemi are you talking about a 331,354,392 C.I. Chrysler Fire Power pre 1959 Hemi or a 426 type Hemi? I think all of the early hemi Fire power Hemi had rope seals, not the later ones like introduced in the mid 1960 or when ever they first came out
Re: Hemi Crankshaft Questions [Re: Cab_Burge] #1517952
10/15/13 07:31 PM
10/15/13 07:31 PM
Vermont
TrWaters Offline OP
TrWaters  Offline OP
Vermont
50's hemi, yes. By problem solver, I am talking an undersized I.D. seal. These originally had rope seals, but some aftermarket rubber seals are made.
Re: Hemi Crankshaft Questions [Re: TrWaters] #1517953
10/15/13 08:03 PM
10/15/13 08:03 PM
How about having the pitted seal area brazed up and refinished
Re: Hemi Crankshaft Questions [Re: TrWaters] #1517954
10/15/13 09:22 PM
10/15/13 09:22 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What about turning it down and having a knurl put back on and using a rope seal ?
Re: Hemi Crankshaft Questions [Re: JohnRR] #1517955
10/15/13 09:43 PM
10/15/13 09:43 PM
Vermont
TrWaters Offline OP
TrWaters  Offline OP
Vermont
That might be my way around this deal. I have $300 in a $300 crankshaft...that isn't worth anything the way it is. I do have several others that need attention in the seal area.
Re: Hemi Crankshaft Questions [Re: TrWaters] #1517956
10/15/13 09:56 PM
10/15/13 09:56 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Shaftech in Ohio, The crank shop, NY.
RIP Monte Smith
Re: Hemi Crankshaft Questions [Re: CompWedgeEngines] #1517957
10/16/13 05:39 PM
10/16/13 05:39 PM
Vermont
TrWaters Offline OP
TrWaters  Offline OP
Vermont
Anyone have a sb crank handy that they could measure the diameter of the rear seal journal?
