Re: help? what is the secret for assembling msd wires???
[Re: mopar_leaner]
#1517725
10/15/13 12:26 AM
10/15/13 12:26 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Get a can of silicone spray, and your problem will be over.Use it first to get the boot on, cut your wire, strip, crimp, then spray again on the wire, spread it lightly with your fingers, and poof...on they go..
RIP Monte Smith
[Re: mopar_leaner]
#1517729
10/15/13 10:19 AM
10/15/13 10:19 AM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
I used Joe's hand cleaner and it worked like a dream, thanks Moparts!!!
I was going to recommend DL hand cleaner Silicone spray is what the wire manufacturers use from what I recall.
DL hand cleaner is also excellent for cleaning your wires
[Re: roadhazard]
#1517730
10/15/13 12:31 PM
10/15/13 12:31 PM
Posts: 5,904 Athens, Greece
Pyper70
Athens, Greece
I use a combination of my wire crimper and that black doohickey they supply you in the box to use with a vise.
I cut it to length, strip off the insulation, bend the center wire back, put on the plug terminal, crimp it down then I spray WD-40 into the boot and slide it on..
which boots are you using ? the short 45º angle ones or the 3" long straight ones?
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
