help? what is the secret for assembling msd wires??? #1517723
10/14/13 11:20 PM
10/14/13 11:20 PM
Hermiston Oregon
mopar_leaner Offline OP
Hermiston Oregon
This is the second set of MSD wires I've have to put together and I need to know what you guys are using to keep the boot sliding on the wires. I cut the wire to size, put Vaseline on the outside, side the boot cover over, crimp the end, and this is where I have the problems.....trying to get the stupid boot to slide back down.
( it takes a Mopar, to beat a Mopar!
email me at moparleaner@gmail.com )
Re: help? what is the secret for assembling msd wires??? [Re: mopar_leaner] #1517724
10/14/13 11:36 PM
10/14/13 11:36 PM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
Try dish washing liquid.
Re: help? what is the secret for assembling msd wires??? [Re: mopar_leaner] #1517725
10/15/13 12:26 AM
10/15/13 12:26 AM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Get a can of silicone spray, and your problem will be over.Use it first to get the boot on, cut your wire, strip, crimp, then spray again on the wire, spread it lightly with your fingers, and poof...on they go..
RIP Monte Smith
Re: help? what is the secret for assembling msd wires??? [Re: CompWedgeEngines] #1517726
10/15/13 03:54 AM
10/15/13 03:54 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
fish oil = WD40
I am truckless..
Re: help? what is the secret for assembling msd wires??? [Re: 340SHORTY] #1517727
10/15/13 06:58 AM
10/15/13 06:58 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Astro-glyde
Re: help? what is the secret for assembling msd wires??? [Re: slantzilla] #1517728
10/15/13 09:13 AM
10/15/13 09:13 AM
Hermiston Oregon
Hermiston Oregon
I used Joe's hand cleaner and it worked like a dream,
thanks Moparts!!!
Re: help? what is the secret for assembling msd wires??? [Re: mopar_leaner] #1517729
10/15/13 10:19 AM
10/15/13 10:19 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
thanks Moparts!!!
I was going to recommend DL hand cleaner
Silicone spray is what the wire manufacturers use from what I recall.
DL hand cleaner is also excellent for cleaning your wires
Re: help? what is the secret for assembling msd wires??? [Re: roadhazard] #1517730
10/15/13 12:31 PM
10/15/13 12:31 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
I use a combination of my wire crimper and that black doohickey they supply you in the box to use with a vise.
I cut it to length, strip off the insulation, bend the center wire back, put on the plug terminal, crimp it down then I spray WD-40 into the boot and slide it on..
which boots are you using ? the short 45º angle ones or the 3" long straight ones?
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: help? what is the secret for assembling msd wires??? [Re: Pyper70] #1517731
10/15/13 04:06 PM
10/15/13 04:06 PM
I cut the wire to length first, slide the boot on, (with silicone gel they supply,I save all the excess ) either type, and then install the terminal ends and then slide the boot over the terminals
Re: help? what is the secret for assembling msd wires??? [Re: mopar_leaner] #1517732
10/15/13 09:30 PM
10/15/13 09:30 PM
tucson az
frank Offline
frank  Offline
tucson az
Dawn dish washing soap
