did e bodies ever have a trunk light? #1517671
10/14/13 10:29 PM
10/14/13 10:29 PM
albany ny
0
05dakota Offline OP
05dakota  Offline OP
albany ny
Re: did e bodies ever have a trunk light? [Re: 05dakota] #1517672
10/14/13 10:30 PM
10/14/13 10:30 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Yes.
Re: did e bodies ever have a trunk light? [Re: Alaskan_TA] #1517673
10/14/13 10:31 PM
10/14/13 10:31 PM
albany ny
0
05dakota Offline OP
05dakota  Offline OP
albany ny
and pics of one?
Re: did e bodies ever have a trunk light? [Re: 05dakota] #1517674
10/14/13 10:54 PM
10/14/13 10:54 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
Not the best picture, but where he scew is is the mount for the light.
If needed I can take a better pic tomorrow.
Re: did e bodies ever have a trunk light? [Re: 67vertman] #1517675
10/14/13 11:20 PM
10/14/13 11:20 PM
albany ny
0
05dakota Offline OP
05dakota  Offline OP
albany ny
where is the switch mounted?
Re: did e bodies ever have a trunk light? [Re: 05dakota] #1517676
10/14/13 11:23 PM
10/14/13 11:23 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
It's a mercury switch.
Re: did e bodies ever have a trunk light? [Re: burdar] #1517677
10/14/13 11:26 PM
10/14/13 11:26 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Part of the AO1 light package..Mercury switch is in the bulb socket..Trunk goes up,light comes on...
Re: did e bodies ever have a trunk light? [Re: 05dakota] #1517678
10/14/13 11:32 PM
10/14/13 11:32 PM
Hermiston Oregon
mopar_leaner Offline
Hermiston Oregon
here is one on a 1971 cuda.
( it takes a Mopar, to beat a Mopar!
email me at moparleaner@gmail.com )
Re: did e bodies ever have a trunk light? [Re: mopar_leaner] #1517679
10/14/13 11:36 PM
10/14/13 11:36 PM
albany ny
0
05dakota Offline OP
05dakota  Offline OP
albany ny
ok thanks. i will never find 1 but at least i know what it is.
Re: did e bodies ever have a trunk light? [Re: 05dakota] #1517680
10/15/13 05:34 AM
10/15/13 05:34 AM
albany ny
0
05dakota Offline OP
05dakota  Offline OP
albany ny
did other mopars used a mercury switched trunk light?
Re: did e bodies ever have a trunk light? [Re: 05dakota] #1517681
10/15/13 03:00 PM
10/15/13 03:00 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Re: did e bodies ever have a trunk light? [Re: Challenger 1] #1517682
10/15/13 03:18 PM
10/15/13 03:18 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
is that a rear defogger I spy?
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: did e bodies ever have a trunk light? [Re: 05dakota] #1517683
10/15/13 11:00 PM
10/15/13 11:00 PM
Harrisburg, Pa.
Harrisburg, Pa.
I would say yes...The mopars from that era should have the mercury switch it was quick and simple to add on the assembly line...The shape and/or size of the unit,bulb and/or connectors might vary...Check out this auction for the 74 monaco trunk light...The unit looks pretty close at a quick glance except for the harness connector.. LINK
Here's a pic of the E body piece submitted in a previous post..In the E-bodie's case this harness acts as a jumper...Unplug the already present harness connection near the left trunk hinge and plug in the AO1 trunk light...
Those harness connectors are used at other locations on the E-body so you could make one up if you had the bulb/switch and some spare parts around for the task..
Re: did e bodies ever have a trunk light? [Re: 05dakota] #1517684
10/16/13 12:37 AM
10/16/13 12:37 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Older B bodies (70 and back) and A bodies had a regular contact switch that was on a welded on tab on the left side of the trunk. The 71 up B bodies and E bodies had the same set up , I'm sure.
Re: did e bodies ever have a trunk light? [Re: 05dakota] #1517685
10/16/13 01:02 AM
10/16/13 01:02 AM
San Francisco
dilvoy Offline
dilvoy  Offline
San Francisco
Yup they sure did. The never fail mercury switch. I would have myserious dead batteries from time to time. Did not figure it was the stuipd mercury switch turning on the light when I was parked facing down hill on some of these San Francisco Hills. I only figured it out when I had the well liner removed from one of my Convertibles. LOL. That's when I removed the trunk bulbs from all of my cars. The utility was not worth having to avoid parking in certain sides of the streets.
Re: did e bodies ever have a trunk light? [Re: dilvoy] #1517686
10/16/13 03:03 AM
10/16/13 03:03 AM
albany ny
0
05dakota Offline OP
05dakota  Offline OP
albany ny
any idea how to add a light ?
Re: did e bodies ever have a trunk light? [Re: 05dakota] #1517687
10/16/13 09:57 AM
10/16/13 09:57 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Question is if you want originality vs functionality. Dakota's have a mercury switch hood light that could be mounted and work, and easy to find, but would be '1970s correct'.
Adding one would be fairly simple, supply a battery positive wire, the light should ground through itself to the chassis
**Photobucket sucks**
Re: did e bodies ever have a trunk light? [Re: 05dakota] #1517688
10/16/13 06:55 PM
10/16/13 06:55 PM
Columbus, GA
Michael Ecks Offline
Columbus, GA
They may not be "common" but they aren't ultra rare either. At least I don't think they are... I decided I wanted one for my challenger when I rewired three years ago, looked on ebay, and did buy it now for one up that day for 20 bucks or so.
Either I got a good deal or they are still out there.
The connector was already there on my tail light harness, plug and play.
Otherwise, if you aren't going for show judging points you can probably easily modify one from another model. if it doesn't have the same connector, Terminal Supply Company probably has one that will fit.
Truth be told I don't think mine even has a bulb in it at the moment. Left the trunk open for a car show and came back to a dead battery. At least there were plenty of car guys around to help with a jump off.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
