Engine masters playing with the numbers????? *DELETED*
#1517621
10/14/13 09:16 PM
10/14/13 09:16 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Post deleted by MattW
Re: Engine masters playing with the numbers!!!!!!
[Re: MattW]
#1517626
10/15/13 11:17 AM
10/15/13 11:17 AM
BradH
Just wanted to acknowledge that the numbers are posted are not realistic at all. Especially Mondays #'s
I'll be the first to admit that the EMC scoring system confuses me, but what's the basis for claiming the #s aren't realistic?
Are you insinuating "happy" dynos, or that the scores don't align with the reported results, or... ?
[Re: BradH]
#1517627
10/15/13 11:34 AM
10/15/13 11:34 AM
Posts: 1,051 The Great White North
RAMM
I would have to look at how many ft/lbs per cube was produced to detect any unrealistic results. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: AndyF]
#1517631
10/15/13 04:25 PM
10/15/13 04:25 PM
BradH
It is a "power under the curve" type of measurement not "peak power".
Makes me think they ought to take it to the next level of "Theoretical Racing" and have all the competitors input their actual EMC dyno results into a drag simlulation package w/ spec gears, weight, tire size, etc. and see who the 'puter says is the quickest & fastest down the simulation track.
[Re: ProSport]
#1517633
10/16/13 01:40 PM
10/16/13 01:40 PM
Posts: 12,422 Kalispell Mt.
HotRodDave
Kalispell Mt.
I don't understand all the negativity toward the engine builder contests it is supposed to be a friendly competition to determine the best engine builder/best engines with out the variable of chassis and drive-line and track prep... just gets you an idea where to go when you want a good engine or the best engine or a good engine on a budget... Maybe there should be a chassis competition where they take identical engines and pass them out to chassis builders and see who can make it run the fastest down the track On the 8 4 2 1 headers on one side of the engine, it is because they have two exhaust valves on each port.
[Re: HotRodDave]
#1517634
10/16/13 01:58 PM
10/16/13 01:58 PM
Posts: 345 Nebraska
451Cuda
Nebraska
These contests are major PR for engine builders - their livelihoods depend on a solid reputation of making big power. Might be a friendly competition for the little guy hobbyists, but it's serious business for big name builders.
[Re: bwdst6]
#1517637
10/16/13 03:22 PM
10/16/13 03:22 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
It’s the scoring! Taking the area under the HP curve is misleading. If you run an engine where you set the transbrake at 5000 off the line and shift at 7000-8000 then mostly what you care about is how much power you’re producing around your shift point.
I would hope they are also making allowances for engine displacement.
What about all the guys that foot brake?
