Pinion seal replacement 8.75 742 case. #1517517
10/14/13 05:53 PM
10/14/13 05:53 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline OP
elmor353  Offline OP
E
Need to change the pinion seal on my 742 case. Been trying to find a replacement seal and the parts store keeps telling me there are several different sizes. WTF? Are there different ID and OD dimensions for a 742? And what is the torque setting for tightening the pinion nut?
Re: Pinion seal replacement 8.75 742 case. [Re: elmor353] #1517518
10/14/13 05:58 PM
10/14/13 05:58 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
742 case is a 1 3/4" diameter pinion I believe. 1.375/1.38 is the 741 case and the 489 is 1.875".
Don't be the exception.
Re: Pinion seal replacement 8.75 742 case. [Re: elmor353] #1517519
10/14/13 06:13 PM
10/14/13 06:13 PM
Ask for and buy both pre 1968 or older 8 3/4 pinion seals in the catatlog and bring the one you don't use back for a return, most auto parts stores will do that when there is more than one part number for the same year car and parts involved I use 150 ft lbs on the torque wrench and then add some pull to make sure thier tight If your changing the seal in the car you will have a hard time getting that much torque on it without a really good air 1/2 inch Hipo impact gun I use a big pipe wrench on the pinion yoke to hold it while tightening the pinion nut, it helps to have a helper hold the pipe wrench so you can use both hands on the torque wrench to pull with
Re: Pinion seal replacement 8.75 742 case. [Re: elmor353] #1517520
10/15/13 12:34 AM
10/15/13 12:34 AM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
#7216
RIP Monte Smith
Re: Pinion seal replacement 8.75 742 case. [Re: CompWedgeEngines] #1517521
10/15/13 04:29 AM
10/15/13 04:29 AM
E
elmor353 Offline OP
elmor353  Offline OP
E
Thanks guys. You always save my bacon. I owe y'all a beer.
Re: Pinion seal replacement 8.75 742 case. [Re: elmor353] #1517522
10/15/13 04:32 AM
10/15/13 04:32 AM
E
elmor353 Offline OP
elmor353  Offline OP
E
About the only one I can buy a beer for and thank face to face is Mr Cab Burge. Catch you at the NW Mopar nationals in Woodburn next year.
