Re: Pinion seal replacement 8.75 742 case.
[Re: elmor353]
#1517518
10/14/13 05:58 PM
10/14/13 05:58 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
742 case is a 1 3/4" diameter pinion I believe. 1.375/1.38 is the 741 case and the 489 is 1.875".
[Re: elmor353]
#1517520
10/15/13 12:34 AM
10/15/13 12:34 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
RIP Monte Smith
