Re: cylinder 1 3 6 burning oil
[Re: dodgeram1998]
#1516870
10/14/13 12:37 AM
10/14/13 12:37 AM
Posts: 43,303 Bend,OR USA
Cab_Burge
big block I don't think its possible to suck from the gasket.
What Only if you are using a valley cover with no connection to the lifter valley I've had many BB suck oil into the bottom of the intake ports, many, many, many, Pull the carb. and take a good bright light and look down into the intake manifold and ports, if it shines you have oil in there ![](/ubbthreads/images/graemlins/Twocents.gif)
