Which Mc Leod Pressure Plate Clutch/Disc should I buy? #1516756
10/13/13 02:25 PM
10/13/13 02:25 PM
Fremont, CA.
Topcat Offline OP
Topcat  Offline OP
Fremont, CA.
I plan on buying a new Mc Leod Pressure Plate and clutch disc this week.
I found out there are choices in the Borg & Beck units.
360156 6 roller
2350 clamp load, 10.95". wide 3 finger
360153 3 roller 10.95". wide 3 finger.
I'm using the over center spring so no diaphram clutch option. Bellhousing is a 70 Mopar OEM big block bellhousing. 485 stroked Hemi. Street only use.
What do you recommend and is there disc options I should know about as well. Thanks
Re: Which Mc Leod Pressure Plate Clutch/Disc should I buy? [Re: Topcat] #1516757
10/13/13 08:19 PM
10/13/13 08:19 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
The McLeod 3 finger set ups are either remanned older units (USA made) if your lucky, or current overseas newer made units (they'll have a made in China label), which are prone to failure, the "new" McLeod clutch discs are not any better, with most complaints being loss of the friction materials...IMHO your better off sourcing a Sachs or Luk cover and disc,...my recommendation is a 3 finger BorgBeck in the 2600-2800 lbs range and a Kevlar disc, makes for a nice street/strip set up, Sachs would be my first choice....3 finger set ups are getting harder to locate, I'd recommend either Keisler Engineering, or American Power Train for a Sachs source
Mike
Re: Which Mc Leod Pressure Plate Clutch/Disc should I buy? [Re: DAYCLONA] #1516758
10/14/13 01:48 AM
10/14/13 01:48 AM
Fremont, CA.
Topcat Offline OP
Topcat  Offline OP
Fremont, CA.
Kiesler, I've heard too many horror stories on customer service. A little hesitant to buy there.
American Powertrain. I looked up their website and didn't find clutches under their mopar category.
Re: Which Mc Leod Pressure Plate Clutch/Disc should I buy? [Re: Topcat] #1516759
10/14/13 09:37 AM
10/14/13 09:37 AM
NY
Beep Beep Offline
Beep Beep  Offline
NY
I would recommend the twin disc from Mcleod. That's what I am using. Stay away from AP. been there and done that.
Re: Which Mc Leod Pressure Plate Clutch/Disc should I buy? [Re: Topcat] #1516760
10/14/13 11:06 AM
10/14/13 11:06 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
From personal experience, I would say to run as fast as you can from American Power Train. They might could have a decent product, but its a bunch of lug nuts working out of a hole in the wall wear house. They do not make any clutch components what so ever, everything is farmed out. I could elaborate on this story,but just take my word for it. I am going to use a McLoud twin disc. Brewers has the best price.
Re: Which Mc Leod Pressure Plate Clutch/Disc should I buy? [Re: 71birdJ68] #1516761
10/14/13 01:58 PM
10/14/13 01:58 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I bought a flywheel from AP. There's nothing wrong with the product but I'll never deal with them again.
Re: Which Mc Leod Pressure Plate Clutch/Disc should I buy? [Re: Stanton] #1516762
10/14/13 06:43 PM
10/14/13 06:43 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
They don't make their flywheels, they are made in Cal. from what they told me.That was the best part that they sent me.
Re: Which Mc Leod Pressure Plate Clutch/Disc should I buy? [Re: Topcat] #1516763
10/14/13 10:58 PM
10/14/13 10:58 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
There are few discussions going on over in the race/tech section with good information on pressure plates and discs
I would use a Borg/Beck/Long pressure plate if I were buying new.They have a smooth and easy lever action with quick release for crisp power shifts
Gus
64 Plymouth Savoy
Dana 60
Re: Which Mc Leod Pressure Plate Clutch/Disc should I buy? [Re: fourgearsavoy] #1516764
10/15/13 09:51 AM
10/15/13 09:51 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
I have the McLeod street twin in my 65 coronet w/440(18 spline) for 13 years with no problems.
Re: Which Mc Leod Pressure Plate Clutch/Disc should I buy? [Re: 65rbdodge] #1516765
10/15/13 11:30 AM
10/15/13 11:30 AM
...gently down the stream
LAR_414 Offline
LAR_414  Offline
I just put this in mine. Highly recommended.
B&B / Long with 600 series Disc....all McLeod.
