no reverse lights, 08 2500 4x4 #1516546
10/13/13 03:22 AM
10/13/13 03:22 AM
iowa
wesw Offline OP
wesw  Offline OP
iowa
my dad used the truck to move our boat and now I have no reverse lights and it has no fuse for it. all the other lights work fine. so now what should I look for next ? will I have to take it to the dealer to get them fixed ? thanks wes
598 ci predator
Re: no reverse lights, 08 2500 4x4 [Re: wesw] #1516547
10/13/13 11:37 AM
10/13/13 11:37 AM
Tidewater, VA
TMCCuda Offline
TMCCuda  Offline
Tidewater, VA
Check the power distribution center under the hood. I know there are separate fuses for left and right trailer signals....probable something similar for back up lamps.
I would also check the trailer wiring pigtails at the rear bumper/ tail light area.
1970 Plymouth Barracuda 1994 Ram 1500 4x4 5.2L 2004 Ram 1500 4x4 5.7L Quad Cab
Re: no reverse lights, 08 2500 4x4 [Re: TMCCuda] #1516548
10/13/13 04:15 PM
10/13/13 04:15 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
You may have tripped one of the internal circuit breakers in the Totally Integrated Power Module, or TIPM under the hood. It may require a scan tool to reset it.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: no reverse lights, 08 2500 4x4 [Re: 71yelladustr] #1516549
10/14/13 06:19 PM
10/14/13 06:19 PM
iowa
wesw Offline OP
wesw  Offline OP
iowa
You may have tripped one of the internal circuit breakers in the Totally Integrated Power Module, or TIPM under the hood. It may require a scan tool to reset it. [/quote
both reverse light bulbs were blown and had to have TIPM reset. it had a code for voltage loss to the turbo also. both of them had the same time stamp on them. all of that just for plugging the boat trailer in with the truck running. thanks wes
598 ci predator
Re: no reverse lights, 08 2500 4x4 [Re: wesw] #1516550
10/15/13 12:10 AM
10/15/13 12:10 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
check the wiring harness going to the actuator on the turbo. they were known to chafe there.
