46RH/47RH questions re: swapping #1516534
10/13/13 02:54 AM
10/13/13 02:54 AM
Nampa, Idaho
W
Wyle E Coyote Offline OP
W
Nampa, Idaho
It's become apparent to me that I can't reach my drivability goals with my truck without an overdrive transmission. This is going into my converted Scout 2 that now sports a 360/727/D20 combo. So going to the OD transmission will be relatively easy. What I need to know is what models that used them have a passenger's side drop for the transfer case. I plan on using the matching transfer case, (a NP 241 if memory serves) to make things easier, though I know I will have to make new drivelines and shift linkages. But it's easier than doing all of that AND building a new front axle. Any other advice, hints, tips, tricks, etc. would be greatly appreciated. Thanks everyone!
25 Dodge Roadster
66 D100 440/727 (on 72 D100 chassis)
67 W200 360/727
72 IH TravelAll 1110 4x4 345/727/NP205
76 Scout 2 360/727/D20
'08 Dakota SLT Quad Cab 4wd 4.7L
Re: 46RH/47RH questions re: swapping [Re: Wyle E Coyote] #1516535
10/13/13 03:28 AM
10/13/13 03:28 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
starting in 94 they were drivers drop...
I am truckless..
Re: 46RH/47RH questions re: swapping [Re: Wyle E Coyote] #1516536
10/13/13 08:46 AM
10/13/13 08:46 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
And what goals would they be?
Re: 46RH/47RH questions re: swapping [Re: redraptor] #1516537
10/13/13 01:57 PM
10/13/13 01:57 PM
hooziewhatsit Online content
hooziewhatsit  Online Content
Early 90s 2500+ I think it was, had married np205s with a passenger side drop.
It took me quite a while to find that 205.
Re: 46RH/47RH questions re: swapping [Re: redraptor] #1516538
10/14/13 02:39 AM
10/14/13 02:39 AM
Nampa, Idaho
W
W
Nampa, Idaho
Mainly I want to get my RPM's down at freeway speeds. Right now, I'm running 31's with 3.54 gears, and she turns about 3k at 70. Even when I run my 33's on it, it doesn't help much. The gearing for it is perfect for most everything else I do with it really. I just need another gear for highway cruising.
25 Dodge Roadster
67 W200 360/727
Re: 46RH/47RH questions re: swapping [Re: Wyle E Coyote] #1516539
10/14/13 08:34 PM
10/14/13 08:34 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Sounds reasonable. Also sounds like a lot of work. I gotta a buddy who wants an O.D. tranny for his slanty cuz of the same reason. Dunno, with the money spent you won't get any realized gas savings for a long time and I don't recall saying about an old car in the junkyard it's there because the motor was over-revved driving across the country. Just sayin'. Take pics for us.
Ok, now everyone beat me up.
Re: 46RH/47RH questions re: swapping [Re: redraptor] #1516540
10/14/13 09:57 PM
10/14/13 09:57 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I broke a lot of stuff just driving across the country, but it wasn't exactly at the posted speed limit.
You can beat me up now. Gene
Re: 46RH/47RH questions re: swapping [Re: redraptor] #1516541
10/15/13 04:18 AM
10/15/13 04:18 AM
Nampa, Idaho
W
W
Nampa, Idaho
I realize that the lower RPM's by themselves won't help much with milage, but combined with EFI it will. As it is right now, to go the speed limit of 75 (outside the metro area), I am turning over 3,000. I see no need for that if I can avoid it.
And the EFI I am referring to is a converted GM TBI system I have. Let the beatings begin.
25 Dodge Roadster
67 W200 360/727
Re: 46RH/47RH questions re: swapping [Re: Wyle E Coyote] #1516542
10/15/13 02:20 PM
10/15/13 02:20 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
All these "beatings" you guys sure this isn't an S&M thread?
Re: 46RH/47RH questions re: swapping [Re: Wyle E Coyote] #1516543
10/15/13 03:11 PM
10/15/13 03:11 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
So, how hard was it to convert the GM unit to the small block Mopar? You were going to do a "how to" on that, right? Gene
Re: 46RH/47RH questions re: swapping [Re: Wyle E Coyote] #1516544
10/15/13 08:43 PM
10/15/13 08:43 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
That sounds cool. I'd like to hear more about that. It's interesting that 3.54 gears and 33" tires wouldn't give you a comfortable highway RPM.
Re: 46RH/47RH questions re: swapping [Re: redraptor] #1516545
10/15/13 09:05 PM
10/15/13 09:05 PM
Nampa, Idaho
W
W
Nampa, Idaho
Here's the best source for the EFI info:
http://www.binderplanet.com/forums/showthread.php?t=47254
25 Dodge Roadster
67 W200 360/727
