75 440 question
#1516521
10/13/13 02:12 AM
10/13/13 02:12 AM
Posts: 1,306 Laveen, Arizona
GTSDart340
Laveen, Arizona
i just picked up a 75 5T440T for $75. first off, what were these engines used in? second, it is destined to go into my 72 D200. it had center dump exhaust manifolds on it, and they were both identical. would this have come out of say, a D/W300 or something bigger? how would i be able to tell if the motor mount brackets are correct for my 72? im going from a 318 to the 440, are the trucks like the cars in that the k-member is different for big/small blocks? or did they use the same one in all the trucks? i will post pics of the brackets and manifolds if need be. thanks!!
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: 75 440 question
[Re: demon]
#1516524
10/15/13 01:09 AM
10/15/13 01:09 AM
GTSDart340
Laveen, Arizona
so how long are the mount brackets for a 2wd. the ones i have on the motor now are about 4" long, from the end that bolts to the engine to the part the mount bolts to. would it make a huge difference if i used 4wd mounts on a 2wd? sorry, this is my first small block to big block conversion. thanks!!
Re: 75 440 question
[Re: GTSDart340]
#1516525
10/15/13 11:46 AM
10/15/13 11:46 AM
dogdays
5 = 1975 model year T = Trenton plant 440 = big motor T = TRUCK
R.
If there's an "E" on the pad it's a cast crank engine.
Re: 75 440 question
[Re: GTSDart340]
#1516526
10/15/13 01:58 PM
10/15/13 01:58 PM
Posts: 993 Mid Michigan
Mr. Smurf
Mid Michigan
I used 4x4 mounts on my 2wd, everything fit fine, no issues.
Ed
Re: 75 440 question
[Re: Mr. Smurf]
#1516527
10/15/13 02:10 PM
10/15/13 02:10 PM
Posts: 8,064 Iowa
76dodgeboy
Iowa
Ed
I had a he11 of a time getting the trans crossmember into place in my 2wd with 4wd mounts. Theres company that sells them for both 2 and 4wd
Re: 75 440 question
[Re: 76dodgeboy]
#1516530
10/19/13 08:50 PM
10/19/13 08:50 PM
GTSDart340
Laveen, Arizona
it also has a front sump pan on it. im thinking this might have been a motor home engine, as it had what was left of a mouse in the valley pan. that leads me to believe it was sitting for a while, and the owners just decided to scrap the engine rather than try to fix it. the pistons are stamped 030, so it has been rebuilt at one time. im probably going to pull it apart, clean it, rering and rebearing it, and see what happens. anything else i need to look out for? btw it does have the forged crank in it. thanks guys!!
Re: 75 440 question
[Re: GTSDart340]
#1516531
10/20/13 11:09 AM
10/20/13 11:09 AM
Posts: 15,487 Florida
scratchnfotraction
if it has a front sump pan,it may have a windage tray like my 77 RV 440 had. I turned it around and use the tray with the rear sump pan with no fitment issues. no, you can not just turn the front sump pan around and use it...i tried that. no worky.
Re: 75 440 question
[Re: scratchnfotraction]
#1516532
10/20/13 04:50 PM
10/20/13 04:50 PM
Posts: 1,652 Amarillo, Tx
old_goat
Six Abuser
Six Abuser
Amarillo, Tx
Summitt has the pan, pickup tube and dipstick for about a hundred bucks. I bought one, no issues.
84 D150 440/727 79 /6 swb D150 1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
Re: 75 440 question
[Re: old_goat]
#1516533
10/28/13 01:21 AM
10/28/13 01:21 AM
GTSDart340
Laveen, Arizona
so since it is the front sump pan, and probably out of a motorhome, will the engine mount brackets work with my 72 D200? or will i have to find different ones? how about modifying a small block one to work?
