75 440 question #1516521
10/13/13 02:12 AM
10/13/13 02:12 AM
Laveen, Arizona
GTSDart340 Offline OP
Laveen, Arizona
i just picked up a 75 5T440T for $75. first off, what were these engines used in? second, it is destined to go into my 72 D200. it had center dump exhaust manifolds on it, and they were both identical. would this have come out of say, a D/W300 or something bigger? how would i be able to tell if the motor mount brackets are correct for my 72? im going from a 318 to the 440, are the trucks like the cars in that the k-member is different for big/small blocks? or did they use the same one in all the trucks? i will post pics of the brackets and manifolds if need be. thanks!!
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: 75 440 question [Re: GTSDart340] #1516522
10/13/13 10:36 AM
10/13/13 10:36 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
What oil pan does it have? Front sump or rear? Trucks used center dump manifold. Rear sump is truck. The crossmember is the same for all motors
Re: 75 440 question [Re: GTSDart340] #1516523
10/13/13 11:56 AM
10/13/13 11:56 AM
Canada
demon Offline
demon  Offline
Canada
The cars don't use different K members for big and small blocks except the 73 to 78 B bodies.
The trucks all have the big and small block holes in the crossmember.
The engine brackets from any big block truck will bolt right in. The 2 wheel drive mounts are taller than the 4wd mounts though so get the right ones.
Pickups use center dump manifolds, the dipstick is in the oil
pan which is a rear sump, and a plug is installed in the engine block dipstick hole.
Re: 75 440 question [Re: demon] #1516524
10/15/13 01:09 AM
10/15/13 01:09 AM
Laveen, Arizona
Laveen, Arizona
so how long are the mount brackets for a 2wd. the ones i have on the motor now are about 4" long, from the end that bolts to the engine to the part the mount bolts to. would it make a huge difference if i used 4wd mounts on a 2wd? sorry, this is my first small block to big block conversion. thanks!!
Re: 75 440 question [Re: GTSDart340] #1516525
10/15/13 11:46 AM
10/15/13 11:46 AM
dogdays Offline
dogdays  Offline
5 = 1975 model year
T = Trenton plant
440 = big motor
T = TRUCK
R.
If there's an "E" on the pad it's a cast crank engine.
Re: 75 440 question [Re: GTSDart340] #1516526
10/15/13 01:58 PM
10/15/13 01:58 PM
Mid Michigan
Mr. Smurf Offline
Mr. Smurf  Offline
Mid Michigan
I used 4x4 mounts on my 2wd, everything fit fine, no issues.
Ed
Re: 75 440 question [Re: Mr. Smurf] #1516527
10/15/13 02:10 PM
10/15/13 02:10 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Ed
I had a he11 of a time getting the trans crossmember into place in my 2wd with 4wd mounts. Theres company that sells them for both 2 and 4wd
Re: 75 440 question [Re: 76dodgeboy] #1516528
10/15/13 02:20 PM
10/15/13 02:20 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Re: 75 440 question [Re: 76dodgeboy] #1516529
10/15/13 02:30 PM
10/15/13 02:30 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
These are 4wd mounts. Driver side
Re: 75 440 question [Re: 76dodgeboy] #1516530
10/19/13 08:50 PM
10/19/13 08:50 PM
Laveen, Arizona
Laveen, Arizona
it also has a front sump pan on it. im thinking this might have been a motor home engine, as it had what was left of a mouse in the valley pan. that leads me to believe it was sitting for a while, and the owners just decided to scrap the engine rather than try to fix it. the pistons are stamped 030, so it has been rebuilt at one time. im probably going to pull it apart, clean it, rering and rebearing it, and see what happens. anything else i need to look out for? btw it does have the forged crank in it. thanks guys!!
Re: 75 440 question [Re: GTSDart340] #1516531
10/20/13 11:09 AM
10/20/13 11:09 AM
scratchnfotraction Offline
if it has a front sump pan,it may have a windage tray like my 77 RV 440 had.
I turned it around and use the tray with the rear sump pan with no fitment issues.
no, you can not just turn the front sump pan around and use it...i tried that. no worky.
Re: 75 440 question [Re: scratchnfotraction] #1516532
10/20/13 04:50 PM
10/20/13 04:50 PM
Amarillo, Tx
old_goat Offline
Six Abuser
old_goat  Offline
Six Abuser
Amarillo, Tx
Summitt has the pan, pickup tube and dipstick for about a hundred bucks. I bought one, no issues.
84 D150 440/727
79 /6 swb D150
1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
Re: 75 440 question [Re: old_goat] #1516533
10/28/13 01:21 AM
10/28/13 01:21 AM
Laveen, Arizona
Laveen, Arizona
so since it is the front sump pan, and probably out of a motorhome, will the engine mount brackets work with my 72 D200? or will i have to find different ones? how about modifying a small block one to work?
