Piston to deck height...how far down @ tdc? #1516217
10/12/13 04:44 PM
10/12/13 04:44 PM
Rochester, NY
superb70 Offline OP
superb70  Offline OP
Rochester, NY
I am working on a stock 76 400 motor and was wondering how far down the pistons are typically down in the cylinder at tdc from the factory? Thanks!
Re: Piston to deck height...how far down @ tdc? [Re: superb70] #1516218
10/12/13 05:15 PM
10/12/13 05:15 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Don't be surprised if they are -.120".
Kevin
Re: Piston to deck height...how far down @ tdc? [Re: Twostick] #1516219
10/12/13 06:04 PM
10/12/13 06:04 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
Don't be surprised if they are at least -.120".
Kevin
Re: Piston to deck height...how far down @ tdc? [Re: JohnRR] #1516220
10/12/13 09:07 PM
10/12/13 09:07 PM
You dont wanna know
Re: Piston to deck height...how far down @ tdc? [Re: RapidRobert] #1516221
10/13/13 11:40 AM
10/13/13 11:40 AM
Rochester, NY
superb70 Offline OP
superb70  Offline OP
Rochester, NY
Well I pulled a head just to find out! .105 down is the answer
Re: Piston to deck height...how far down @ tdc? [Re: superb70] #1516222
10/13/13 11:51 AM
10/13/13 11:51 AM
Yes a 400 begs for a 470 cube conversion. offset ground 440 crank & the only hard part is the expense of the stroker pistons. 470 is alot of cubes & it is in a compact package (smaller B as opposed to RB block exterior dimentions) & should weigh less. You can get quench & the right SCR. Heads would have to be a consideration & good ones would be the next step up
