Page 3 of 3 1 2 3
Re: Disk Brakes on C-body [Re: 72d100] #1516080
10/23/13 01:48 PM
10/23/13 01:48 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Yes but not quite that thick.
You can also use a drum brake hub.
Be aware that if you use a multi-piston caliper you will need to make sure the spokes on your wheels do not hit the caliper. Oz had to arrange custom wheels for the hot rod.
If you're sticking with a sliding caliper the caliper clearance is far less critical.
- Stu Harmon
Re: Disk Brakes on C-body [Re: feets] #1516081
11/07/13 03:47 AM
11/07/13 03:47 AM
Hamburg / Germany
Den300 Offline
Den300  Offline
Hamburg / Germany
@Jyrki: Any picture update for us?
Hamburg/Germany
69 Chrysler 300
446cui Dual Quad
12.64 @ 110.7
Re: Disk Brakes on C-body [Re: Den300] #1516082
11/08/13 08:47 AM
11/08/13 08:47 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
Have forgotten the whole thing everytime there is someone in the garage with a working digicamera..., but eventually....
Plynouth VIP '67 TT IC EFI
Re: Disk Brakes on C-body [Re: jyrki] #1516083
11/09/13 08:25 AM
11/09/13 08:25 AM
Hamburg / Germany
Den300 Offline
Den300  Offline
Hamburg / Germany
Are you rebuilding the VIP?
Hamburg/Germany
69 Chrysler 300
446cui Dual Quad
12.64 @ 110.7
Re: Disk Brakes on C-body [Re: Den300] #1516084
11/10/13 01:36 AM
11/10/13 01:36 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Why not use ford explorer brakes, dual piston calipers, 5x4.5 rotors with the right register and a simple bracket to mount them on the drum spindle. Vhalla done. Or you can look at the crown vic rotors, same deal 12.02 diameter, 2.85 center hole, dual piston calipers, and a simple bracket. Vhalla! Done
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Disk Brakes on C-body [Re: astjp2] #1516085
11/10/13 11:26 AM
11/10/13 11:26 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Vhalla! Done
Sending him to Viking Paradise?
Don't be the exception.
Re: Disk Brakes on C-body [Re: Den300] #1516086
11/15/13 06:02 PM
11/15/13 06:02 PM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
just a repaint and a vinyl roof! And going through the drivetrain.
Anyway, I finally go some pics of the B-body wilwoods installed on C-body drum brakes They don't tell much I guess, the adpters between the caliber adapter and the spindle is two 3mm aluminum plates, so 6 mm together. Don't remeber wether I reversed the caliber attchment or not, but maybe someone with B-body assembly can tell? Anyway, the installation was pretty stright forward once I figured it out, the biggest task was making the "shims" with basic hand tools.
Re: Disk Brakes on C-body [Re: jyrki] #1516087
11/15/13 06:04 PM
11/15/13 06:04 PM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
Another
Re: Disk Brakes on C-body [Re: jyrki] #1516088
11/15/13 06:05 PM
11/15/13 06:05 PM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
Third one
Re: Disk Brakes on C-body [Re: Den300] #1516089
12/22/13 03:19 PM
12/22/13 03:19 PM
Calgary, AB, Canada
73EStroker Offline
73EStroker  Offline
Calgary, AB, Canada
Flo und Den
I had to log in here as I wanted to respond. I would suggest you email Doctor Diff (look up his website) as he has everything you need to give 4 wheel discs, including park brake, for a budget of around $1300ish. His front kit uses 11-3/4" C Body rotors and slider caliper brackets and the rear kit fits your differential housing and uses Toyota discs, adapters for Cobra Calipers and is a 10.7" disc which gives the correct pro portioning front to rear. These kits fit inside your 15" wheels. His name is Cass and he resides in Montana. Best to talk/email with him first though.
Good Luck
Re: Disk Brakes on C-body [Re: 73EStroker] #1516090
12/24/13 08:15 AM
12/24/13 08:15 AM
Hamburg / Germany
Den300 Offline
Den300  Offline
Hamburg / Germany
@73EStroker: I do know Cass as I already ordered some from him for my 65 Dodge Coronet
But I am sure I read somewhere that somebody asked him not long ago and at the moment
he offers nothing for C-Bodies. Apart from that he really has great solutions for brakes!
Hamburg/Germany
69 Chrysler 300
446cui Dual Quad
12.64 @ 110.7
Re: Disk Brakes on C-body [Re: Den300] #1516091
01/03/14 01:46 PM
01/03/14 01:46 PM
Berlin, Germany
Flo Offline OP
Flo  Offline OP
Berlin, Germany
Also had talked to Cass, but no C-body stuff.
Thanks regardless
Flo
1967 Fury III 4door HT tiny 318, late model roller block, bored and stroked to 344
Re: Disk Brakes on C-body [Re: AndyF] #1516092
01/10/14 06:29 PM
01/10/14 06:29 PM
Cleveland, OH
fury413rb Offline
fury413rb  Offline
Cleveland, OH
I used to make a 13 inch kit for C-body cars. I stopped building the kit since it was really slow seller, but it shouldn't be too hard to duplicate if you want some good brakes.
What was the application/part number on those brake rotors?
Re: Disk Brakes on C-body [Re: fury413rb] #1516093
01/10/14 08:37 PM
01/10/14 08:37 PM
AndyF Offline
AndyF  Offline
I started with a Mercedes rotor and then made some modifications.
Page 3 of 3 1 2 3
