Exhaust bolt/stud sealer #1516014
10/12/13 08:35 AM
10/12/13 08:35 AM
Mt.Gilead, Ohio
OhioMopar Offline OP
Mt.Gilead, Ohio
What do you use to seal the exhaust bolts/studs in the heads on your big block? I am using ARP bolts, and I've never really used sealer before, and I've also never had them leak. So I guess I'll try it this time.
Thanks!
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Exhaust bolt/stud sealer [Re: OhioMopar] #1516015
10/12/13 09:22 AM
10/12/13 09:22 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Some use gold Permatex.I use silver anti sieze and never had a leak with bolts.Now I run studs in my headers with just a bolt where a stud wont go.Rocky
Chrysler Firepower
Re: Exhaust bolt/stud sealer [Re: therocks] #1516016
10/12/13 09:32 AM
10/12/13 09:32 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
I used ARP bolts for the first time. Never had a problem before now. I'm guessing the oxide finish is too smooth?
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Exhaust bolt/stud sealer [Re: OhioMopar] #1516017
10/12/13 11:13 AM
10/12/13 11:13 AM
I'd highly suggest using OE shouldered studs & trim the outer fine threaded portion till just enough threads remain so the nut fits flush. Any more length is a waste & hampers header fitment. You can also source a higher grade nut that is thinner so you can trim em even more. To ans your Q I would suggest Permatex #1 gasket cement in the toothpaste like tube. It is thick/viscous & dries rock hard. "the right stuff" gasket cement tho pricey is even better. Clean the holes with a small bottle brush/brake kleen first till the holes are clean & dry so the cement will get a better grip
Re: Exhaust bolt/stud sealer [Re: RapidRobert] #1516018
10/12/13 12:05 PM
10/12/13 12:05 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Can anyone give me a part # for an ARP stud kit that will fit our 906 heads? (Header application)
Looked at various sites, but came up empty on a kit that referenced BB MOPAR??
Thanks, Joe
Re: Exhaust bolt/stud sealer [Re: RapidRobert] #1516019
10/12/13 02:02 PM
10/12/13 02:02 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
I didn't use studs, they are 3/8 headed shoulder bolts. Thank you.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Exhaust bolt/stud sealer [Re: OhioMopar] #1516020
10/12/13 02:24 PM
10/12/13 02:24 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Dorman makes the studs.I bought new ones at a local auto parts store.I even got thick washers there.Total was about 12 bucks.I even run studs in my aluminum heads with no water at the holes.Rocky
Chrysler Firepower
Re: Exhaust bolt/stud sealer [Re: therocks] #1516021
10/12/13 02:37 PM
10/12/13 02:37 PM
Spokane Washington
ScottSmith_Harms Online content
Mr Wizzard
ScottSmith_Harms  Online Content
Mr Wizzard
Spokane Washington
It's all I use, fantastic stuff for most of your engines gasket sealant needs.
Re: Exhaust bolt/stud sealer [Re: ScottSmith_Harms] #1516022
10/12/13 03:32 PM
10/12/13 03:32 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Right Stuff is RTV not made for hi heat temps like exhaust.The copper is made for heat.Clean surface and good gaskets dont require RTV.Ive replaced thousands of parts at work and home over 40 years.Never used both.Rocky
Chrysler Firepower
Re: Exhaust bolt/stud sealer [Re: therocks] #1516023
10/12/13 04:43 PM
10/12/13 04:43 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I agree that it might not have been designed for exhaust studs, but I've used it since the 90's when it first came out and it's worked just fine for exhaust studs, zero failures.
Re: Exhaust bolt/stud sealer [Re: ScottSmith_Harms] #1516024
10/12/13 07:41 PM
10/12/13 07:41 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Thanks to all of you. Probably get some of the Right Stuff.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Exhaust bolt/stud sealer [Re: OhioMopar] #1516025
10/12/13 11:11 PM
10/12/13 11:11 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Loctite Thread sealer is all I've ever used on any threads that entered liquid(coolant) for many years now...zero issues!
