Vacuum Pump Question
#1515646
10/11/13 07:35 PM
10/11/13 07:35 PM
Posts: 474 Alberta, Canada
451Guy
Alberta, Canada
Hey Guys,
I am thinking about putting a vacuum pump on my 512 race motor. It is currently not set up perfectly for a pump but I will change that on the next freshen. Looking for suggestions with regards to who's to use, how many viens, drive system, Mounting location etc. Any advise would be greatly appreciated.
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T Best ET 11.39 @ 118.11
Re: Vacuum Pump Question
[Re: dvw]
#1515650
10/12/13 02:51 PM
10/12/13 02:51 PM
Posts: 2,131 New Lenox IL
cudadon
New Lenox IL
If you research it the GZ pulls as much vacuum as you'll ever need for a fair price. Mounts easily with their kit . Pull from the front of the rocker cover. Pulls very little oil. I might empty 2oz every 10-15 passes. Doug
I like that hose. You can see oil. Is that in their kit? How much for hose and fittings? Thanks, Don
[Re: cudadon]
#1515651
10/12/13 03:38 PM
10/12/13 03:38 PM
Posts: 9,872 MI, usa
dvw
MI, usa
It all came with the kit. Or you buy parts separate. Summit carries the fittings also. http://www.gzmotorsports.com Doug
[Re: dvw]
#1515652
10/12/13 07:12 PM
10/12/13 07:12 PM
Posts: 126 Oregon
Jamie McGrath
Doug, it looks real clean and I bet it run's like the scalded cat, but you forgot a valve cover nut on the front.
[Re: Jamie McGrath]
#1515653
10/12/13 08:43 PM
10/12/13 08:43 PM
dvw
MI, usa
There's one there now. I've checked the lash 6 times in 100 passes. ET is a work in progress. 9.25@146.6, 3340 lbs Doug
