70's factory Mopar power locks....how did they work? #1515117
10/10/13 09:50 PM
10/10/13 09:50 PM
minnarusta
TX9H6E4CUDA Offline OP
minnarusta
A derby guy I know just got in a 1976 Cordoba with power locks (push on knob both/doors lock or unlock). I want to incorporate this into my 1971 Superbee so what do I need to grab from the Cordoba to make sure I get everything? How does the mechanisms tell each other what to do?
Any help is appreciated
For the absolute best powder coating go to J.I.T powder coating, contact infomation is in my personal profile..
Re: 70's factory Mopar power locks....how did they work? [Re: TX9H6E4CUDA] #1515118
10/10/13 10:23 PM
10/10/13 10:23 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
The door lock buttons operate switches in the doors that operate solenoids connected to the door latches. There is relay inside the passenger kick panel as well.
You'd want the lock rods and clips, solenoids, switches and wiring (or at least the connectors) and the relay.
I don't know if it will all bolt in a '71, but since they're both B bodies it just might.
Re: 70's factory Mopar power locks....how did they work? [Re: 440newport] #1515119
10/12/13 09:20 AM
10/12/13 09:20 AM
COLLINGWOOD, ONT
71_deputy Offline
71_deputy  Offline
COLLINGWOOD, ONT
as said- get everything- the door wiring from the 76 may have other wiring- use or cut it out.
