Page 6 of 7 1 2 3 4 5 6 7
Re: Post your engine compartment pics with E.T. [Re: WBR] #1514704
10/15/13 11:52 AM
10/15/13 11:52 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Nice pics!
1.28
5.92
115mph
Re: Post your engine compartment pics with E.T. [Re: FastmOp] #1514705
10/15/13 09:30 PM
10/15/13 09:30 PM
St. Croix, US Virgin Islands
David_in_St_Croi Offline
Michelle's ride:
Factory iron head, 7: 1 compression (service manual has timing specs for 65 octane), factory stock solid roller cam, aftermarket Pierce aluminium intake manifold, Weber 32/36 DGV carby, four speed, 4.7 rear, 32" tires, Lucas sport coil, Pertronix module installed in dizzy
Best run last Sunday, with me driving, 1/8th mile:
reaction: .587
60ft:2.834
1/8th: 14.130
Speed: 46.88 (that is MPH, not KPH at least)
At least one 60 ft was better but ET was worst
Most recent modification, clean idle jets, replace fuel filter. The vise grips have been on there since she got the car in 1999.
My ride:
Most recent best:
1/2 mile in five minutes up our hill from old apartment to new house at the end of tow strap behind M's ride:
Nothing like building a house to throw off schedules of every other project.
It has done an 11.56 with the 452 and me driving which has to be worth a couple of tenths slowing it down. New mill which is in Dan Costello's very capable hands should do better.
https://www.facebook.com/THENEWCDRA
Proud member of the liberal scientific elite
Re: Post your engine compartment pics with E.T. [Re: MadMopars] #1514706
10/22/13 02:39 AM
10/22/13 02:39 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
512c.i.--Indy SRs--.590 lift flat tappet cam--2580#--89 Lebaron--1.18 60ft--5.47 at 125MPH--8.59 at 156MPH
Re: Post your engine compartment pics with E.T. [Re: MadMopars] #1514707
10/22/13 05:19 AM
10/22/13 05:19 AM
Topeka ks
N
Nxdodge Offline
Nxdodge  Offline
N
Topeka ks
440. 452 heads.580 solid.old trw domes
7.62 1/8 mile 88mph
1.68 60ft
3700lbs
Re: Post your engine compartment pics with E.T. [Re: Nxdodge] #1514708
10/22/13 06:26 PM
10/22/13 06:26 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
Mild 408LA street car
Barely in the 12s @108
And after paint:
Needs a wiring tidy-up and new foam on the scoop plate
Re: Post your engine compartment pics with E.T. [Re: qwkmopardan] #1514709
10/22/13 08:39 PM
10/22/13 08:39 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Okay Dan, now let's see the Demon...
Re: Post your engine compartment pics with E.T. [Re: cudadoug] #1514710
10/22/13 08:55 PM
10/22/13 08:55 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
here is mine...451, 14.1 comp, rons toilet, 727, 5600 8" verta, 4.56 gear, 2 1/8 headers...still pushing to finish before the end of the year..
Re: Post your engine compartment pics with E.T. [Re: earthmover] #1514711
10/23/13 01:24 AM
10/23/13 01:24 AM
cudadoug Offline
cudadoug  Offline
Here's my junk project that never gets worked on...LOL
Hope it goes mid 11's (next spring?) with a warmed up 360...driven to and from the track.
Re: Post your engine compartment pics with E.T. [Re: cudadoug] #1514712
10/23/13 01:34 AM
10/23/13 01:34 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Something appears to be missing there
Re: Post your engine compartment pics with E.T. [Re: cudadoug] #1514713
10/23/13 01:41 AM
10/23/13 01:41 AM
Tucson AZ,
MadMopars Offline OP
Tucson AZ,
How about a pic of the whole car? I'm thinking I'm going to put my Dart back to Gold and always like to see others for inspiration. That will get you off the hook for having no motor.
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: Post your engine compartment pics with E.T. [Re: MadMopars] #1514714
10/23/13 06:36 AM
10/23/13 06:36 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
9.89 @ 134 mph 1.349 60 ft. 451" (440) 3400 lbs.
Re: Post your engine compartment pics with E.T. [Re: Bigbeep] #1514715
10/23/13 10:09 AM
10/23/13 10:09 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
1.389 60' 6.43 @ 105.50 1/8th, 10.23 @ 121.78
448" ported 915's & flat tappet, S/S springs, foot brake 3325#
Re: Post your engine compartment pics with E.T. [Re: roadhazard] #1514716
10/23/13 12:35 PM
10/23/13 12:35 PM
Alberta, Canada
451Guy Offline
451Guy  Offline
Alberta, Canada
Not as impressive as Al's but have gone 11.10 at 138 with a 1.72 - 60 ft. 512 with Indy Dash 1's , 3100 lbs
Sorry, I tried everything I know to post this correctly but it keeps coming up like this!!!! UGGGH
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank
Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car
Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T
Best ET 11.39 @ 118.11
Re: Post your engine compartment pics with E.T. [Re: cudadoug] #1514717
10/24/13 03:28 PM
10/24/13 03:28 PM
Sparta, TN
mark42202 Offline
mark42202  Offline
Sparta, TN
446, 915 heads, 3424lbs. Best ET was a 6.74 @ 102, but I only have a vid of a 6.75 @ 102. This is my street cruiser/ show car.
Video:
http://www.youtube.com/watch?v=eH-5MvIBIJk
Any more details on the combo? My car is a little heavier but it hasn't ran faster than a 7.61 so far. Camshaft. Gear? I wanna run a 6 too!
[quote=]Any more details on the combo? My car is a little heavier but it hasn't ran faster than a 7.61 so far. Camshaft. Gear? I wanna run a 6 too!
I'd like to know more about this combo as well. A mid 10 second B body with a kickdown linkage. AWESOME ! ! !
Sorry for the delayed reply guys! It has 915 heads that have had serious port and polish work done. It is a stock stroke forged crank, .055 over bore cylinders. The cam is a Bullet hydraulic roller 305/318 duration 525int/ 513exh lift with Bullet roller lifters, and ductile adjustable rockers with K Motion springs. The compression is 11.5:1 with Venolia flat top pistons zero decked with napier cut rings. The trans is a push button with a Turbo Action 3000 9" convertor, and a 4.30 spool in the 8.75 rear end. I leave off the foot brake at 2900 and leave the trans in drive and let it shift itself (with the governor I have in it, it shifts at 5600).
Re: Post your engine compartment pics with E.T. [Re: Bigbeep] #1514718
10/24/13 06:22 PM
10/24/13 06:22 PM
Norwalk Ohio
cudasteve68 Offline
cudasteve68  Offline
Norwalk Ohio
Why are you so heavy?
You have AAR fenders like mine correct?
Mine is 3250
How much lighter is a 8-3/4" then a Dana?
Re: Post your engine compartment pics with E.T. [Re: WBR] #1514719
10/24/13 06:38 PM
10/24/13 06:38 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Just an almost stock 360, with one little modification.
10.08@136mph (3700 lbs)
Re: Post your engine compartment pics with E.T. [Re: MadMopars] #1514720
10/24/13 06:42 PM
10/24/13 06:42 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
79 Chrysler "300"--4100 lbs--360/408--Ported production cyl heads,[587 castings]--Full exhaust w/4 mufflers--1.58 60ft.--7.29 at 96--11.60 at 116
Re: Post your engine compartment pics with E.T. [Re: qwkmopardan] #1514721
10/24/13 06:53 PM
10/24/13 06:53 PM
Stockholm, Sweden
TomsCharger70 Offline
Stockholm, Sweden
Here is mine.
496cid. INDY EZ Heads, rollercam, etc.. Best ET so far 10.74@125Mph, got more left in it.
60ft 1.57 (Needs some suspension work). Weight about 1700kg.
/Tom
Re: Post your engine compartment pics with E.T. [Re: TomsCharger70] #1514722
10/24/13 09:44 PM
10/24/13 09:44 PM
Mn.
daytona5812 Offline
daytona5812  Offline
Mn.
606 wedge, 1.14 60 ft, 7.82 at 176 @ 2620 lbs
Re: Post your engine compartment pics with E.T. [Re: daytona5812] #1514723
10/24/13 11:27 PM
10/24/13 11:27 PM
VA.
mosweethemi Offline
mosweethemi  Offline
VA.
Hello A picture of our 1970 Plymouth Road Runner 440 sixpack car fy1
