Whipash Cam Disappointment #1514112
10/08/13 06:14 PM
10/08/13 06:14 PM
Maine
P
Pettyblue340 Offline OP
P
Maine
Is this right I thought these cams were suppose to give great throttle response and sound awesome
I think it sounds exactly the same as the stock cam and actually more sluggish.
I emailed Hughes to see whats up and no response yet.
I wasnt expecting a miracle out of my 318 but would assume it would sound and pull slightly better
Time for a 340 or 360 I guess
1974 Roadrunner 29K original Mile survivor 1973 Challenger 340
Re: Whipash Cam Disappointment [Re: Pettyblue340] #1514113
10/08/13 06:18 PM
10/08/13 06:18 PM
Renton Washington
Triple Threat Offline
Renton Washington
Where was the cam installed? And whats the rest of the combo?
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Whipash Cam Disappointment [Re: Pettyblue340] #1514114
10/08/13 06:30 PM
10/08/13 06:30 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
If you have a problem, call them about it. Don't try and communicate the lack of satisfaction via e-mail.
Re: Whipash Cam Disappointment [Re: Triple Threat] #1514115
10/08/13 06:36 PM
10/08/13 06:36 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
What are the specs? Is it the flat tappet 318 whiplash for LA, 360 flat tappet for LA, 5.2 whiplash roller for Magnum, or 5.9 whiplash roller for Magnum?
The 5.9 whiplash roller in my 5.9 magnum lopes pretty good. Pulls good, has good throttle response, and is everything they promised.
Mine is 222/228 @ .050, 107 LSA installed at 104
Pulls to about 5200 rpm put 285 HP and 325 tq to the rear wheels. The rest of my combo is a junkyard 5.9 (stock heads, stock pistons) the 2bbl M1 EFI intake, headers into 3" exhaust, and the PCM tuned with SCT.
http://youtu.be/51lfmIW4bz4
http://youtu.be/U9wBb66U3rY
http://youtu.be/u4YXAdjfO6o
**Photobucket sucks**
Re: Whipash Cam Disappointment [Re: 70Cuda383] #1514116
10/08/13 06:50 PM
10/08/13 06:50 PM
Maine
P
P
Maine
Its on my 74 Roadrunner was bone stock 318 2 barrel
I ordered the whiplash cam because I wanted the sound and performance and everyone loves them.
The 318 whiplash Cam a Wieand Action Plus and a Eddy 600 carb were installed by a friend who is a full time engine builder/Mechanic. he built my 340 which runs sounds and goes excellent!
I am not on here to bash Hughes as I have ordered a lot of good parts from them over the years and I was not expecting hemi power from a cam. I just dont understand why it has no Lope in it and why its so sluggish.
Im wondering if the wrong cam made it to the box..
Re: Whipash Cam Disappointment [Re: Pettyblue340] #1514117
10/08/13 07:37 PM
10/08/13 07:37 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Do you know what Intake centerline your mechanic installed the cam at is? That can make a difference. That vid wouldnt work on my pute.
Re: Whipash Cam Disappointment [Re: Sport440] #1514118
10/08/13 09:03 PM
10/08/13 09:03 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Every flat tappet cam ive broken in seemed to lope more after it was run for a while. Where is your timing? Sounds like your motor is laboring, and at a high idle too. Im guessing you are running manifolds as well?
Re: Whipash Cam Disappointment [Re: Sport440] #1514119
10/08/13 09:05 PM
10/08/13 09:05 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Ignition timing will have tons to do with how that cam responds.
Re: Whipash Cam Disappointment [Re: RobX4406] #1514120
10/08/13 09:11 PM
10/08/13 09:11 PM
Sounds more than stock.
Re: Whipash Cam Disappointment [Re: Hot 340] #1514121
10/09/13 09:23 AM
10/09/13 09:23 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
now that I'm on my computer and I listened to the original video, I agree.
Tune the motor. idle sounds like it's up at about 1000-1200 rpm. dial it back to 750 and see what you get then. if it won't idle that low, find out why...timing off? idle mixture off? vacuum leaks?
Re: Whipash Cam Disappointment [Re: Pettyblue340] #1514122
10/09/13 10:04 AM
10/09/13 10:04 AM
Delray beach, Florida
P
Performance Only Offline
P
I think my first question would be; Did you degree the cam or just line up the dots/.
2nd question is this; Did anyone bother to check the spec's of the cam? the numbers are inscribed on the cam.
machine shop owner and engine builder
Re: Whipash Cam Disappointment [Re: Pettyblue340] #1514123
10/09/13 11:40 AM
10/09/13 11:40 AM
Washington, IL
Hughes Offline
Hughes  Offline
Washington, IL
Anthony, I am sorry to hear you are having problems with your engine. If a Whiplash cam does not have a lumpy idle then something is definitley wrong. I looked all through our e-mails since the time you ordered the cam and I could not find where you had e-mailed us. Maybe it got caught in the spam folder. Sorry about that. There are several things we should talk about to try and figure out what is going on. If possible, please give us a call and we will get to the bottom of it. We have had almost 100% positive feedback on the Whiplash series of cams so I would really like to get this corrected for you and make you a believer.
Re: Whipash Cam Disappointment [Re: Hughes] #1514124
10/09/13 02:39 PM
10/09/13 02:39 PM
P
Paul_Fancsali Offline
P
Get the total up into the mid 40s and that cam will wake up. I had a 318 with terrible seal that ran in 15s with a cam headers and cast Iron intake 3.55s
Re: Whipash Cam Disappointment [Re: Pettyblue340] #1514125
10/09/13 04:55 PM
10/09/13 04:55 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
a lumbty bumbty idle is over-rated. Get a cam that works. As mentioned tune the car and then see what happens. FWIW your idle is pretty high, drop it to 700 and it will get more lumpy.
Coming soon!!!!
Re: Whipash Cam Disappointment [Re: 70Cuda383] #1514126
10/09/13 05:41 PM
10/09/13 05:41 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Tune, tune and tune some more! I have a Whiplash cam in my 383. At first it was OK performance wise, had a nice rumpity idle and would "bark" the tires from a stop. I was happy with it, but...kept messing with the tune. Now I have it where it will flat blow the 275/60R15 off from a standing start if I'm not careful. And that's just stepping on the go peddle, no burnout or nothing like that. The ol' 383 runs dang strong now, right on up to 6000 RPM. Idles at 750 RPM. Hughes came up with a nice street cam.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Whipash Cam Disappointment [Re: Mr.Yuck] #1514127
10/09/13 07:24 PM
10/09/13 07:24 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
a lumbty bumbty idle is over-rated. Get a cam that works. /quote]
Are you suggesting the whiplash doesn't work? I'd beg to differ and say that it's an awesome street car cam.
Off idle power? Check
Good throttle response? Check
Power band that 'works' in street rpm ranges? Check
Enough vacuum for power brakes? Check
What cam would you reccomend?
Or are you just saying that you prefer a mellow smooth idle? If so, nothing wrong with that. Some guys like quiet, smooth engines, some guys like the sound of spooling turbos, or the sound of a shot of NO2 going off, and some like a lumpy sounding idle.
