Stage V rockers or Barton T & D #1514059
10/08/13 03:46 PM
10/08/13 03:46 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Is either type any better ?
Going on stage V big valve heads. I scrapped the idea of Millinium Heads.
Re: Stage V rockers or Barton T & D [Re: Sammy] #1514060
10/08/13 06:11 PM
10/08/13 06:11 PM
USA
B3RE Offline
B3RE  Offline
USA
I like Barton's setup. Rocker geometry is a breeze to get right. It's why he is back on top in Hemi Super Stock.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
Re: Stage V rockers or Barton T & D [Re: Sammy] #1514061
10/08/13 06:56 PM
10/08/13 06:56 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
All depends on where your at on teh power spectrum...looking for every oz of power (class racing type engine) available and turning some decent RPM then Barton is the way to go. If you are running a bracket type or street engine then I'd say Stage V are what you should go with. The difference in realized power is negletable by teh seat of teh pants. Or if you want to brag on your parts then go with Bartons 'cause they are jewlery!
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Stage V rockers or Barton T & D [Re: Sammy] #1514062
10/08/13 07:42 PM
10/08/13 07:42 PM
Mohnton, Pa
DodgeCharger Offline
Mohnton, Pa
I run the Barton rockers. I never tried anything else. When I built my motor 10 years ago they were the best that were available. I looked hard for an alternative because I couldn't believe how much they cost. I think they were $2500 for the set.
I've had them for 10 years and drive my car on the street and race at the track. I've never had to adjust them. Every time I check them they are where I set them.
I run a 750 lift roller cam.
Re: Stage V rockers or Barton T & D [Re: W.I.N. Racing] #1514063
10/08/13 07:44 PM
10/08/13 07:44 PM
ONTARIO,CANADA
604 Hemi GTX Offline
ONTARIO,CANADA
The price between Barton and Stage 5 isn't a substantial amount, about $500 so it's a personal preference too.
JMO
Kevin
Re: Stage V rockers or Barton T & D [Re: 604 Hemi GTX] #1514064
10/08/13 08:07 PM
10/08/13 08:07 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
There are numerous advantages to the Barton rocker system.
Re: Stage V rockers or Barton T & D [Re: jim sciortino] #1514065
10/08/13 09:17 PM
10/08/13 09:17 PM
With the T&D bartons you don't have take everything apart but the stage Vs will handle a ton of power and revs. I went with the Barons because I got a good deal.
Re: Stage V rockers or Barton T & D [Re: Sammy] #1514066
10/08/13 10:29 PM
10/08/13 10:29 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
I bought the Stage V rockers a few years ago. I don't have too many street miles and only 6 or so strip passes. So far the oiling has not been an issue as it is on other shaft rocker sets that seem to need push rod oiling to correct.
At the time I bought mine the T&D Barton rockers were a lot more expensive. Perhaps the price gap has narrowed?
So far I have no complaints with the Stage V . Cam is a .670 solid roller.
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Stage V rockers or Barton T & D [Re: Hemi Allstate] #1514067
10/09/13 07:29 AM
10/09/13 07:29 AM
pa
572charger Offline
572charger  Offline
pa
barton t-d rockers on mine since 2003 can't go wrong !!!
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: Stage V rockers or Barton T & D [Re: Sammy] #1514068
10/09/13 08:35 AM
10/09/13 08:35 AM
Shelton, Ct.
572_HEMI_Cuda Offline
Shelton, Ct.
I have both STAGE V and the Barton set-up. If you are looking for high rpm shifts then go with Barton. I run STAGE V on my 604" and they are just fine, I shift at 7100.
Re: Stage V rockers or Barton T & D [Re: 572_HEMI_Cuda] #1514069
10/09/13 08:42 AM
10/09/13 08:42 AM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
How many passes per year do you put on your valvetrain? I will be shifting at 7200 rpm's and it's going to be a weekly bracket car. I need longevity.
Re: Stage V rockers or Barton T & D [Re: Sammy] #1514070
10/09/13 09:05 AM
10/09/13 09:05 AM
Shelton, Ct.
Shelton, Ct.
2 yrs ago I made about a 100 passes, the last year not many for a few different reasons. Longevity shouldn't be a problem with either. your consumables will be valve springs not rockers.
Re: Stage V rockers or Barton T & D [Re: 572_HEMI_Cuda] #1514071
10/09/13 01:37 PM
10/09/13 01:37 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
If you can afford the T&D's buy them and don't look back. Less issues, better system ect...
Well worth the extra
Re: Stage V rockers or Barton T & D [Re: Biginchmopar] #1514072
10/09/13 09:28 PM
10/09/13 09:28 PM
JAX FLA
Curt Offline
Curt  Offline
JAX FLA
Dont know if it a concern or not...can you run dual plugs with the Bartons??
Curt
Oh yeah...THAT'S gonna leave a mark!
Re: Stage V rockers or Barton T & D [Re: Biginchmopar] #1514073
10/09/13 10:04 PM
10/09/13 10:04 PM
Shelton, Ct.
Shelton, Ct.
To be honest if you're having issues with stage V rockers, something else is wrong.
Re: Stage V rockers or Barton T & D [Re: Curt] #1514074
10/09/13 10:34 PM
10/09/13 10:34 PM
Mohnton, Pa
Mohnton, Pa
Curt
Definitely not without modification. You may be able to if you modify.
