Re: Stage V rockers or Barton T & D
[Re: Sammy]
#1514060
10/08/13 06:11 PM
10/08/13 06:11 PM
Posts: 561 USA
B3RE
USA
I like Barton's setup. Rocker geometry is a breeze to get right. It's why he is back on top in Hemi Super Stock.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
[Re: Sammy]
#1514061
10/08/13 06:56 PM
10/08/13 06:56 PM
Posts: 2,118 Byron, NY
W.I.N. Racing
Byron, NY
All depends on where your at on teh power spectrum...looking for every oz of power (class racing type engine) available and turning some decent RPM then Barton is the way to go. If you are running a bracket type or street engine then I'd say Stage V are what you should go with. The difference in realized power is negletable by teh seat of teh pants. Or if you want to brag on your parts then go with Bartons 'cause they are jewlery!
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: jim sciortino]
#1514065
10/08/13 09:17 PM
10/08/13 09:17 PM
With the T&D bartons you don't have take everything apart but the stage Vs will handle a ton of power and revs. I went with the Barons because I got a good deal.
[Re: Sammy]
#1514066
10/08/13 10:29 PM
10/08/13 10:29 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
I bought the Stage V rockers a few years ago. I don't have too many street miles and only 6 or so strip passes. So far the oiling has not been an issue as it is on other shaft rocker sets that seem to need push rod oiling to correct. At the time I bought mine the T&D Barton rockers were a lot more expensive. Perhaps the price gap has narrowed? ![](/ubbthreads/images/graemlins/shruggy.gif) So far I have no complaints with the Stage V . Cam is a .670 solid roller.
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: Hemi Allstate]
#1514067
10/09/13 07:29 AM
10/09/13 07:29 AM
Posts: 1,629 pa
572charger
pa
barton t-d rockers on mine since 2003 ![](/ubbthreads/images/graemlins/thumbs.gif) can't go wrong !!!
606 hemi pump gas best 9.60 at 142mph on motor 05 hemi daytona 1500 go-mango 4wd quadcab 2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
[Re: 572_HEMI_Cuda]
#1514069
10/09/13 08:42 AM
10/09/13 08:42 AM
Posts: 1,824 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
I have both STAGE V and the Barton set-up. If you are looking for high rpm shifts then go with Barton. I run STAGE V on my 604" and they are just fine, I shift at 7100.
How many passes per year do you put on your valvetrain? I will be shifting at 7200 rpm's and it's going to be a weekly bracket car. I need longevity.
[Re: Biginchmopar]
#1514072
10/09/13 09:28 PM
10/09/13 09:28 PM
Posts: 1,030 JAX FLA
Curt
JAX FLA
Dont know if it a concern or not...can you run dual plugs with the Bartons?? Curt
Oh yeah...THAT'S gonna leave a mark!
[Re: Biginchmopar]
#1514073
10/09/13 10:04 PM
10/09/13 10:04 PM
Posts: 298 Shelton, Ct.
572_HEMI_Cuda
Shelton, Ct.
If you can afford the T&D's buy them and don't look back. Less issues, better system ect... Well worth the extra
To be honest if you're having issues with stage V rockers, something else is wrong.
[Re: Curt]
#1514074
10/09/13 10:34 PM
10/09/13 10:34 PM
Posts: 2,703 Mohnton, Pa
DodgeCharger
Mohnton, Pa
Definitely not without modification. You may be able to if you modify.
