convertible top adjustment? #1513991
10/08/13 01:33 PM
10/08/13 01:33 PM
albany ny
0
05dakota Offline OP
05dakota  Offline OP
albany ny
on my 68 300 the top frame is over 1/4 inch too high over driverside door/window. how do I fix this?
Re: convertible top adjustment? [Re: 05dakota] #1513992
10/08/13 08:12 PM
10/08/13 08:12 PM
Mid Michigan
Coronet-R/T-Rag Offline
Mid Michigan
Just the door window? How about the rear window, is it lined up? You may just need to pull the door panel and adjust the window. Mine was tilted and I just loosened the nuts that hold the window frame to the door and adjusted the window.
Re: convertible top adjustment? [Re: Coronet-R/T-Rag] #1513993
10/08/13 11:29 PM
10/08/13 11:29 PM
albany ny
0
05dakota Offline OP
05dakota  Offline OP
albany ny
it seems to be ok on back window and front window is all the way up at the wing window.
Re: convertible top adjustment? [Re: 05dakota] #1513994
10/09/13 12:43 AM
10/09/13 12:43 AM
Mid Michigan
Mid Michigan
If you remove the door panel you will see nuts that you can loosen to adjust the height of the whole window assembly. Pretty easy to do. Just loosen the nuts and adjust the window until it's the same height as the back window.
Re: convertible top adjustment? [Re: Coronet-R/T-Rag] #1513995
10/09/13 12:51 PM
10/09/13 12:51 PM
albany ny
0
05dakota Offline OP
05dakota  Offline OP
albany ny
wont that move the vent window assembly?
