Re: 833/od hp limit??
[Re: 76dodgeboy]
#1513870
10/08/13 05:01 AM
10/08/13 05:01 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
The biggest downfall is the alum case and that the countershaft isnt bushed.. I have ripped some darn hard 1 2 and 2 3 shifts in my shorty. The tires have spun before any damage has happened.. I definately wouldnt drag race it.. Your biggest problem is gonna be finding a bell with the 5.125 dia hole and the 833/od833 bolt pattern.. Ma Mopar did have a truck bell that had the 833/od833 NP435/445 bolt pattern but they are rare and expensive..
I am truckless..
[Re: 76dodgeboy]
#1513871
10/08/13 07:17 AM
10/08/13 07:17 AM
Posts: 3,325 Truckville, the capital of NY
85_Ram_4speed
There is no definitive answer, as it depends on the setup. Remember 57Plymouth that used to post? He had a stout 340 in a LRE clone that broke his. I am going to start testing the limits myself though. I have a big block and the general concensous is it probably puts out 400-425 HP and 450-480 Tq. The torque input (what most trans nowadays are rated by) and what you make slip (tires or clutch) are going to be the key to making it live---along with how you shift it, which I say powershifting will eventually blow it apart (shocking any drivetrain parts will eventually take thier toll).
Right now my street tires are definatly my limiting factor. I can spin easily through first and second---even on the track. But what what will happen when I put something more sticky on??....
FYI, you can turn the big 5.125 bearing retainer down to the second bigger 4.807 size so it fits a standard big block bellhousing--or just swap retainers as long as your O/D trans has the 308 front bearing which has the bigger bolt pattern.
Outcast Dodge guy.
[Re: 85_Ram_4speed]
#1513872
10/08/13 07:48 AM
10/08/13 07:48 AM
Posts: 1,518 AZ
Mike P
AZ
"....The biggest downfall is the alum case and that the countershaft isnt bushed...."
I agree and have seen more than one cracked case to prove it (they do make good dummy/mockup units when you gut them however LOL).
I'm not sure what years, but Chrysler did make some of the overdrive 833s with an iron case. I believe they were used exclusively in trucks. I'm using an iron case one in my 57 Plymouth behind a 1st Gen Hemi. I'm not sure, but I believe Brian (57Plymouth) was running an aluminum one in his LRE.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
[Re: 76dodgeboy]
#1513874
10/08/13 05:20 PM
10/08/13 05:20 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Just for giggles. What would it take to install a Hemi 4 speed into the truck? (18 spline IIRC)
I may be able to line Harry up with a guy selling one.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: hp383]
#1513876
10/08/13 06:08 PM
10/08/13 06:08 PM
85_Ram_4speed
Nothing more really than doing a regular 4-speed swap. They only thing going to a BB with a 833 4speed is posibbly some linkage issues, specifficaly with a blowproof, more than likely you'll be fabbing a mount for the z-bar ball on the bellhousing. But in general, a 4-speed swap is pretty straight foward in these trucks and does not require the big floor hump that is normally associated with 4-speed trucks.
I say if all else fails, have a back up trans or a regular 833 to stick in it. I hate blowing stuff up, but I agree, it is fun to bang gears, you just have to be prepared for the consequences. If I had my choice and a couple grand laying around, I'd have Passon build me a 4-speed with thier new aluminum case and thier take on the overdrive gear set (better ratio spread than stock).
Outcast Dodge guy.
[Re: 76dodgeboy]
#1513878
10/08/13 06:25 PM
10/08/13 06:25 PM
hp383
State of Confusion
Can I afford it
I think you might. He has reasonable pricing on it I think.
He didn't want to retire off it last I knew, and hes moving in a few months, and will be selling stuff.
[Re: 76dodgeboy]
#1513880
10/08/13 09:12 PM
10/08/13 09:12 PM
85_Ram_4speed
So I assume the bellhousing you have then is a steel safety style one and only set up for the 435? If that is the case, I have to assume that you can land the top bolts of an 833 on the belhousing and drill those holes out and weld a nut on the backside. The lowers will need tabs more than likely welded to the bell to capture those bolt holes.
I made up a 1/4" plate years ago for when I was using a aluminum 435 factory bell to an 833 trans. On that bell as I said above is what I experienced in bolt hole alignment. I made it work, it seemed to be fine. I had the 1/4" plate bored for the 5.125" front retainer size, you could do it to any size retainer you see fit really. The whole trick with any of this is dial indicating the register for the trans to the back of the crank to get them as close as possible to line up.
On your flywheel that you already have for the 440, as long as its an internal balance and you balance the 383 for internal balance it will work. If you have a external balance 440 flywheel already, you will have to have it rebalanced per your rotating assembly---which most likely means having weld added on to your flywheel or a small slug of mallory metal added to the appropriate spot.
If your flywheel is for an 11 or 12 inch clutch, make sure the bellhousing will fit around it when bolted to the engine and that the starter also lines up. Some bellhousings will only accept the smaller 10.5" clutch flywheel and starter location.
Outcast Dodge guy.
[Re: 76dodgeboy]
#1513883
10/08/13 11:43 PM
10/08/13 11:43 PM
hp383
State of Confusion
Finally going to Tennessee or is his shop too small now
Moving to Mooresville, North Carolina.
Wants a bigger shop as hes outgrown the existing with sales coming in.
Also a larger workforce with all the NASCAR teams in the area.
[Re: 76dodgeboy]
#1513884
10/09/13 07:21 AM
10/09/13 07:21 AM
85_Ram_4speed
I was told 383-440 are balanced the same. Is a 69 440 and 65 383 Both Forged. I got the flywheel and bellhousing together. Im still slowly gathering parts for that build.
Well, there was two cast crank 440 engines---one with the "sixpack" rods and a normal stock rod crank, as well as a forged crank. But if you got the flywheel from someone else, it really doesn't matter what your putting it on, just in fact what it came off of. So if it cam off a internal balanced 440, then you should be all set for your 383. The balancer that was on the 440 would be the dead givaway of what that motor was----but be forwarned, it is easy to make an external balance motor internally balaned too, via adding slugs of mallory metal to the crank to get it rebalanced.
And then we have the fact that everything now is 30+ years old and people sometimes do dumb things when swapping parts. My truck was a perfect example of that, it had a 360 (which is externally balanced)in it when I bought it, but a non 360 flexplate/weighted converter. It had a heck of a vibration to it until I discovered what the previous owner did. So sometimes people just assume if it bolts together then it must be ok.
Outcast Dodge guy.
