Do you use Roloc discs to clean gasket surfaces?
#1513620
10/07/13 05:52 PM
10/07/13 05:52 PM
Posts: 2,091 Delray beach, Florida
Performance Only
Here's a good reason not to.
machine shop owner and engine builder
Re: Do you use Roloc discs to clean gasket surfaces?
[Re: Performance Only]
#1513621
10/07/13 06:00 PM
10/07/13 06:00 PM
Guitar Jones
Yes I do but only very slowly and lightly and never on a head gasket sealing surface or aluminum.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: 6bblFLASH]
#1513623
10/07/13 06:15 PM
10/07/13 06:15 PM
Triple Threat
Renton Washington
Guilty, those scotch brite ones are so handy!
#1513627
10/07/13 07:27 PM
10/07/13 07:27 PM
Performance Only
That first picture was after taking .004 off the deck. In this one you can see more clearly where the Roloc disc dug in a little harder. Obviously the blue spots are the LOW spots.
#1513629
10/07/13 07:34 PM
10/07/13 07:34 PM
Performance Only
And here is the finished deck cut .008" The problem is that some engines don't have gaskets available to make up the difference. This one happens to be supercharged, so .008 off ther deck and about the same off the head just about takes this little guy out of pump gas range without doing some other creative things to keep the pistons from hitting the chambers.
#1513635
10/07/13 08:24 PM
10/07/13 08:24 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Was the damage done with an oatmeal raisin, or chocolate chip cookie? In all seriousness, I have seen the damage from cookies as well, and also the leftover from Scotchbrite pads, Most people simply cant, or dont clean things well enough, and you may as well throw a handful of fiberglass dust in some of these things and get better results....you really need to be careful with any Scothbrite type products as shown here for sure.
RIP Monte Smith
[Re: CompWedgeEngines]
#1513636
10/07/13 08:49 PM
10/07/13 08:49 PM
Posts: 1,130 Dayton, Ohio
wldtm
Dayton, Ohio
What are you suppose to use? The plastic scraper idea is crap!
The picture proves a nice point. Unfortunately, if a machinist gets a hold of an engine that a flat rate technician has touched it probably had a roloc bristle or scotch style touch the engine.
If anyone has a better way to clean a sealing surface that is aluminum or iron, I am all ears.
Thanks for the picture
Justin
Interested in having you car wired? Drag car, street car, EFI swap?
PM for details
[Re: CHAPPER]
#1513639
10/07/13 09:44 PM
10/07/13 09:44 PM
Performance Only
Is this a block that was done at your shop originally, and having a freshen up..??..or is this a block that was brought to you for a new build?? I'm suspecting it is a new build. The deck being off is to be expected. The cleaning with the scuffy pad(if used correctly) would not cause that much damage.
No offense, but you're way off on this one. Look at how flat the one end of the block is. It was perfectly flat. Then look at the area's where the roloc disc removed metal. I see this all the time. All the marks where the dye is left that looks like circular pattern is from metal being removed by the roloc disc. I've seen much worse than this one, but in an effort to dissuade others from making the same mistake, this is the one I took some pictures of. Please don't insult me by trying to tell me those disc's didn't do that. The owner admitted he used them and realized afterwards that it was a mistake when he saw the damage. As far as how do you get the gaskets off, I'd tell you use a gasket remover spray with a scraper, or let your machinist deal with it.
