Page 1 of 3 1 2 3
Do you use Roloc discs to clean gasket surfaces? #1513620
10/07/13 05:52 PM
10/07/13 05:52 PM
Delray beach, Florida
P
Performance Only Offline OP
P
Here's a good reason not to.
machine shop owner and engine builder
Re: Do you use Roloc discs to clean gasket surfaces? [Re: Performance Only] #1513621
10/07/13 06:00 PM
10/07/13 06:00 PM
Guitar Jones Offline
Yes I do but only very slowly and lightly and never on a head gasket sealing surface or aluminum.
Re: Do you use Roloc discs to clean gasket surfaces? [Re: Performance Only] #1513622
10/07/13 06:02 PM
10/07/13 06:02 PM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
Yep,thats the problem
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Do you use Roloc discs to clean gasket surfaces? [Re: 6bblFLASH] #1513623
10/07/13 06:15 PM
10/07/13 06:15 PM
Renton Washington
Triple Threat Offline
Renton Washington
Guilty, those scotch brite ones are so handy!
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Do you use Roloc discs to clean gasket surfaces? [Re: Triple Threat] #1513624
10/07/13 06:17 PM
10/07/13 06:17 PM
CT
GTX MATT Online content
GTX MATT  Online Content
CT
Didn't anyone teach you how to color in between the lines?
Re: Do you use Roloc discs to clean gasket surfaces? [Re: GTX MATT] #1513625
10/07/13 06:23 PM
10/07/13 06:23 PM
Amherst,NY
challengermike Offline
Amherst,NY
correct me if im wrong but it looks the block wasn't decked enough. The marks don't look like a cookie disc. And why would you cookie around the cylinder and not around the hole gasket surface.
Re: Do you use Roloc discs to clean gasket surfaces? [Re: challengermike] #1513626
10/07/13 06:35 PM
10/07/13 06:35 PM
Gilbert AZ
tsanchez Offline
tsanchez  Offline
Gilbert AZ
Scotchbrite is a good way to kill a engine, the abrasive will get in the oil and trash bearings, or if you are incapable of using a buffer wheel you will end up wit surface damage,
Re: Do you use Roloc discs to clean gasket surfaces? [Re: Performance Only] #1513627
10/07/13 07:27 PM
10/07/13 07:27 PM
P
P
That first picture was after taking .004 off the deck. In this one you can see more clearly where the Roloc disc dug in a little harder. Obviously the blue spots are the LOW spots.
Re: Do you use Roloc discs to clean gasket surfaces? [Re: Performance Only] #1513628
10/07/13 07:31 PM
10/07/13 07:31 PM
P
P
Here it is after .006 off the deck.
Re: Do you use Roloc discs to clean gasket surfaces? [Re: Performance Only] #1513629
10/07/13 07:34 PM
10/07/13 07:34 PM
P
P
And here is the finished deck cut .008"
The problem is that some engines don't have gaskets available to make up the difference. This one happens to be supercharged, so .008 off ther deck and about the same off the head just about takes this little guy out of pump gas range without doing some other creative things to keep the pistons from hitting the chambers.
Re: Do you use Roloc discs to clean gasket surfaces? [Re: Performance Only] #1513630
10/07/13 07:37 PM
10/07/13 07:37 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Thanks for sharing. Do you think it would have lived with just .006" off? Is .002" enough to worry about one way or another?
Can you take .008 off the top of the pistons if you can't do it with head gaskets?
Re: Do you use Roloc discs to clean gasket surfaces? [Re: challengermike] #1513631
10/07/13 07:40 PM
10/07/13 07:40 PM
P
P
You'd have to ask the owner for the answer to that. He did tell me he used a cookie to clean the deck and that's exactly what it looks like. I see this kind of thing all the time. Had he not "cookied" it, we could have taken .002 off the deck and all would've been clean and straight. Now he'll be doing some chamber work on the heads instead.
In the end it's no big deal to me, the machine's doing the work, but I thought I'd share this little tidbit for anyone thinking of doing something similar.
Re: Do you use Roloc discs to clean gasket surfaces? [Re: Performance Only] #1513632
10/07/13 07:47 PM
10/07/13 07:47 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Who cares what the dumb tuners do?? Don't look like a Mopar that we mess with to me.
If you like drag racing, support your local track.
Re: Do you use Roloc discs to clean gasket surfaces? [Re: CHAPPER] #1513633
10/07/13 08:00 PM
10/07/13 08:00 PM
Highland beach Fl
P
poisondart2 Offline
poisondart2  Offline
P
Highland beach Fl
Dan, I will write this down so I dont make the same mistake. Dont use a cookie on a block and who would of ever thought a cookie would do well anyway
Re: Do you use Roloc discs to clean gasket surfaces? [Re: poisondart2] #1513634
10/07/13 08:15 PM
10/07/13 08:15 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Some people just shouldn't have tools in their hands
Re: Do you use Roloc discs to clean gasket surfaces? [Re: Performance Only] #1513635
10/07/13 08:24 PM
10/07/13 08:24 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Was the damage done with an oatmeal raisin, or chocolate chip cookie?
In all seriousness, I have seen the damage from cookies as well, and also the leftover from Scotchbrite pads, Most people simply cant, or dont clean things well enough, and you may as well throw a handful of fiberglass dust in some of these things and get better results....you really need to be careful with any Scothbrite type products as shown here for sure.
RIP Monte Smith
Re: Do you use Roloc discs to clean gasket surfaces? [Re: CompWedgeEngines] #1513636
10/07/13 08:49 PM
10/07/13 08:49 PM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
What are you suppose to use? The plastic scraper idea is crap!
The picture proves a nice point. Unfortunately, if a machinist gets a hold of an engine that a flat rate technician has touched it probably had a roloc bristle or scotch style touch the engine.
If anyone has a better way to clean a sealing surface that is aluminum or iron, I am all ears.
Thanks for the picture
Justin
Interested in having you car wired? Drag car, street car, EFI swap? PM for details
Re: Do you use Roloc discs to clean gasket surfaces? [Re: wldtm] #1513637
10/07/13 09:25 PM
10/07/13 09:25 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
They sell a gasket remover in spray form. Scotch pads are what make gaskets weld to the metal cos of all the fine scratches. Besides that, u make a machined surface too irregular.
Re: Do you use Roloc discs to clean gasket surfaces? [Re: Performance Only] #1513638
10/07/13 09:25 PM
10/07/13 09:25 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Is this a block that was done at your shop originally, and having a freshen up..??..or is this a block that was brought to you for a new build?? I'm suspecting it is a new build. The deck being off is to be expected. The cleaning with the scuffy pad(if used correctly) would not cause that much damage.
Re: Do you use Roloc discs to clean gasket surfaces? [Re: CHAPPER] #1513639
10/07/13 09:44 PM
10/07/13 09:44 PM
P
P
No offense, but you're way off on this one. Look at how flat the one end of the block is. It was perfectly flat. Then look at the area's where the roloc disc removed metal. I see this all the time. All the marks where the dye is left that looks like circular pattern is from metal being removed by the roloc disc. I've seen much worse than this one, but in an effort to dissuade others from making the same mistake, this is the one I took some pictures of.
Please don't insult me by trying to tell me those disc's didn't do that. The owner admitted he used them and realized afterwards that it was a mistake when he saw the damage.
As far as how do you get the gaskets off, I'd tell you use a gasket remover spray with a scraper, or let your machinist deal with it.
Page 1 of 3 1 2 3
