4 spd swap #1513228
10/06/13 04:44 PM
10/06/13 04:44 PM
moparkc Offline OP
moparkc  Offline OP
Have the opportunity to get a complete 4 speed set up from a 66 Charger to put in my 70 Road Runner. Both are big block cars. The set up includes pedals, hump, transmission, fly wheel, z bar, shifting rods, bell housung, shifter, new clutch and adjusting rod.
Can anyone tell me will these parts from a 66 Charger swap into a 70 Road Runner? Will the transmission mount from my automtic work?
Any other knowledge of changing from a automatic to 4 speed would be appreciated.
Re: 4 spd swap [Re: moparkc] #1513229
10/06/13 04:54 PM
10/06/13 04:54 PM
Truckville, the capital of NY
85_Ram_4speed Offline
What engine was in the Charger and what engine is in your Roadrunner? I ask because there were different flywheels for different engines depending if they were internal or external balanced and if it was external there still could be a few choices.
Also, if your car currently has a 727 trans, then you should be able to use your current driveshaft as is. If your car has a 904, a new driveshaft will have to be made or an old one of the right size found.
I am not sure on the 66 to 70 useage on parts, as I am more familiar with A-body set ups and they did differ between those years on parts it took to do it. Hopefully someone else will chime ine for you.
Outcast Dodge guy.
Re: 4 spd swap [Re: 85_Ram_4speed] #1513230
10/06/13 05:01 PM
10/06/13 05:01 PM
moparkc Offline OP
moparkc  Offline OP
383 was in the Charger. 400 made to 451 stroker in my Road Runner. Have 727 in RR now.
Re: 4 spd swap [Re: moparkc] #1513231
10/06/13 05:30 PM
10/06/13 05:30 PM
Is the 400 stroker motor internally or exterannly balanced now? If internal your good to go with all the parts for the drivetrain, not sure about the body parts like the clutch pedals, clucth rods, Z bar, tranny hump and so on, sorry 4 speeds are GREAT
Re: 4 spd swap [Re: Cab_Burge] #1513232
10/06/13 05:40 PM
10/06/13 05:40 PM
moparkc Offline OP
moparkc  Offline OP
It is internally balanced. You are correct about 4 speeds, they are a blast. Last one I had was in 70 Cuda with 383,was a lot of fun.
Anybody know about parts fitting?
Re: 4 spd swap [Re: moparkc] #1513233
10/06/13 06:33 PM
10/06/13 06:33 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
...Any other knowledge of changing from a automatic to 4 speed would be appreciated.
Some info here;
http://www.dodgecharger.com/forum/index.php/topic,95764.0.html
Good luck with it! As others have said, stick cars are great! Except maybe in a daily driver.
Re: 4 spd swap [Re: moparkc] #1513234
10/06/13 06:48 PM
10/06/13 06:48 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Most everything should work including the mount.The only part that may have some fitment issues would be the hump.I'm not 100% sure how the body side of the z bar fits you may need some welding there too.
Gus
64 Plymouth Savoy
Dana 60
Re: 4 spd swap [Re: fourgearsavoy] #1513235
10/06/13 09:44 PM
10/06/13 09:44 PM
moparkc Offline OP
moparkc  Offline OP
Moparfan53 thank you for the great link, after reading it I am going to go ahead and get the four speed and tackle the project this winter.
Fourgear savoy you are correct I will need to weld the bracket for the z bar mount on. That is one extra part I will need to get.
Thanks to all for the input, look forward to shifting gears next spring.
Re: 4 spd swap [Re: moparkc] #1513236
10/06/13 11:30 PM
10/06/13 11:30 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Glad it was of help. Let us know how the conversion goes.
Re: 4 spd swap [Re: moparfan53] #1513237
10/08/13 08:26 PM
10/08/13 08:26 PM
Mid Michigan
Coronet-R/T-Rag Offline
Mid Michigan
The pedals are different. 66-67 b body pedals are different from 68-70. The newer pedals will work in the older cars, you just loose your drivers side defroster vent hose (won't fit). Not sure about putting older pedals in the newer car. Never done it. Your transmission cross member will not work straight away. You will have to move the mount on the cross member. Pretty easy modification. As long as the crank in your current motor can except a 4 speed bushing, all else should be good to go.
Re: 4 spd swap [Re: Coronet-R/T-Rag] #1513238
10/08/13 08:43 PM
10/08/13 08:43 PM
Southern by Choice
Shoozy Offline
I have a foot fetish
Shoozy  Offline
Southern by Choice
I used '66 pedals when converting my '70 Bee. Aside from welding the mount on the frame everything else was a simple bolt in. I did have to clearance the seam a tad since I used a Lakewood scattershield. Have fun.
Old, tired, and sometimes broke down. Me, not my car...
Re: 4 spd swap [Re: Shoozy] #1513239
10/09/13 12:47 PM
10/09/13 12:47 PM
North Carolina, USA
Silverbullet2 Offline
North Carolina, USA
Go ahead and spring for a new Hurst competiton plus shifter and pistol grip handle while you're at it!
