alternator wiring question #1512948
10/05/13 08:27 PM
10/05/13 08:27 PM
wisconSIN
Blown61 Offline OP
Blown61  Offline OP
wisconSIN
I have the electronic voltage reg, there is an I and F as I am looking at the back of the alt which wire goes where?
Thanks!
Re: alternator wiring question [Re: Blown61] #1512949
10/05/13 08:35 PM
10/05/13 08:35 PM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
Re: alternator wiring question [Re: MPerry] #1512950
10/05/13 08:42 PM
10/05/13 08:42 PM
wisconSIN
Blown61 Offline OP
Blown61  Offline OP
wisconSIN
http://www.moparts.org/Tech/Archive/elec/21.html
I seen that but which wire goes to which field terminal?? or am I missing something?
Re: alternator wiring question [Re: Blown61] #1512951
10/05/13 08:47 PM
10/05/13 08:47 PM
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
They are both field wires so shouldn't make a difference.
I'd put the blue one on the one closest to the battery feed post.
Re: alternator wiring question [Re: MPerry] #1512952
10/05/13 08:49 PM
10/05/13 08:49 PM
wisconSIN
Blown61 Offline OP
Blown61  Offline OP
wisconSIN
Well there in lies the problem, we tried switching them one nite and burned the wires off, I dont wish to repeat this event.
Re: alternator wiring question [Re: Blown61] #1512953
10/05/13 08:52 PM
10/05/13 08:52 PM
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
what year car? Is this a conversion using an alternator that had a mechanical vr?
Re: alternator wiring question [Re: MPerry] #1512954
10/05/13 08:56 PM
10/05/13 08:56 PM
wisconSIN
Blown61 Offline OP
Blown61  Offline OP
wisconSIN
61 and yes it was converted, I was having low charging, so I switched alts and then was getting high charging so my buddy switched the wires on the back and it burned off the "I" wire. Is there a certain alt that goes with the electronic vr?
thanks
Re: alternator wiring question [Re: Blown61] #1512955
10/05/13 09:04 PM
10/05/13 09:04 PM
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
Yes!One of those terminals must be going to ground. If you look at that diagram the case is grounded. The blue wire is ignition voltage so if it goes to ground the wire will smoke when you flip the key on.
Re: alternator wiring question [Re: MPerry] #1512956
10/05/13 09:09 PM
10/05/13 09:09 PM
wisconSIN
Blown61 Offline OP
Blown61  Offline OP
wisconSIN
That would explain why all the magic smoke came out of the wire, so I need the alt with the six square windows on the back of it?
Re: alternator wiring question [Re: Blown61] #1512957
10/05/13 09:18 PM
10/05/13 09:18 PM
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
Re: alternator wiring question [Re: MPerry] #1512958
10/05/13 09:30 PM
10/05/13 09:30 PM
wisconSIN
Blown61 Offline OP
Blown61  Offline OP
wisconSIN
Thank you very much for your time and helping me with this! have a great weekend!
