Re: alternator wiring question
[Re: MPerry]
#1512952
10/05/13 08:49 PM
10/05/13 08:49 PM
Posts: 1,572 wisconSIN
Blown61
wisconSIN
They are both field wires so shouldn't make a difference. I'd put the blue one on the one closest to the battery feed post.
Well there in lies the problem, we tried switching them one nite and burned the wires off, I dont wish to repeat this event.
[Re: MPerry]
#1512954
10/05/13 08:56 PM
10/05/13 08:56 PM
Blown61
wisconSIN
what year car? Is this a conversion using an alternator that had a mechanical vr?
61 and yes it was converted, I was having low charging, so I switched alts and then was getting high charging so my buddy switched the wires on the back and it burned off the "I" wire. Is there a certain alt that goes with the electronic vr?
thanks
[Re: MPerry]
#1512956
10/05/13 09:09 PM
10/05/13 09:09 PM
Blown61
wisconSIN
Yes!One of those terminals must be going to ground. If you look at that diagram the case is grounded. The blue wire is ignition voltage so if it goes to ground the wire will smoke when you flip the key on.
That would explain why all the magic smoke came out of the wire, so I need the alt with the six square windows on the back of it?
