Tuff Wheels and Rimblows #1512863
10/05/13 05:47 PM
10/05/13 05:47 PM
Spokane Valley, WA
Big Bad Bee Offline OP
Spokane Valley, WA
Does a gasket go between the steering wheel and the three bolt column adapter?
Lindy
I’m listening.
Re: Tuff Wheels and Rimblows [Re: Big Bad Bee] #1512864
10/05/13 07:07 PM
10/05/13 07:07 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
i did not see a sign of one on any adapters
Re: Tuff Wheels and Rimblows [Re: AARCONV] #1512865
10/05/13 07:23 PM
10/05/13 07:23 PM
Spokane Valley, WA
Spokane Valley, WA
That adapter isn't in the 70 B Coronet/Charger FSM as far as I could find. If anyone has an A body FSM I would appreciate knowing if it had a gasket (I don't suspect there is one) and what the torque specs on the three bolts are.
I’m listening.
Re: Tuff Wheels and Rimblows [Re: Big Bad Bee] #1512866
10/06/13 10:59 PM
10/06/13 10:59 PM
TC, Minnesota
Gabmando Offline
Gabmando  Offline
TC, Minnesota
My 73 Charger Rallye has a TUFF wheel from the factory. No gasket.
Re: Tuff Wheels and Rimblows [Re: Gabmando] #1512867
10/07/13 03:18 AM
10/07/13 03:18 AM
Spokane Valley, WA
Spokane Valley, WA
Thank you!
~Lindy~
I’m listening.
Re: Tuff Wheels and Rimblows [Re: Big Bad Bee] #1512868
10/07/13 10:05 AM
10/07/13 10:05 AM
USA
ramairthree Offline
ramairthree  Offline
USA
74 RR,
factory tuff wheel
(yeah, half the foam has fallen off, but it is original)
No gasket.
Re: Tuff Wheels and Rimblows [Re: ramairthree] #1512869
10/07/13 10:15 AM
10/07/13 10:15 AM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
Definitely no gasket, Lindy.
As for torque specs on the nuts I'd say, snug, but don't go crazy. They're not under any significant force that would cause them to loosen up, though if you're really concerned, then blue Loctite won't hurt.
The nut for the adapter to the steering column is a different matter and any that I've removed have had some evidence of threadlocker on them.
Re: Tuff Wheels and Rimblows [Re: YYZ] #1512870
10/07/13 11:50 AM
10/07/13 11:50 AM
Elk Grove, Calif.
bigblock340power Offline
Elk Grove, Calif.
No gasket here either!
Re: Tuff Wheels and Rimblows [Re: YYZ] #1512871
10/07/13 04:11 PM
10/07/13 04:11 PM
Spokane Valley, WA
Spokane Valley, WA
Vlad, I did the German tightening method... Goodentight! I've got the column in and the wheel mounted. Dang it looks great. Thanks for your generosity and help.
Check this out!
I’m listening.
