cat. converter delete on a 2008 dully with a 6.7 #1512213
10/04/13 04:13 PM
10/04/13 04:13 PM
sc
tjmarcus1 Offline OP
sc
what has to be done to make it work? This is a mid year production truck.
Re: cat. converter delete on a 2008 dully with a 6.7 [Re: tjmarcus1] #1512214
10/04/13 04:31 PM
10/04/13 04:31 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Are you asking about DPF delete on a diesel ?
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: cat. converter delete on a 2008 dully with a 6.7 [Re: bigdad] #1512215
10/04/13 05:03 PM
10/04/13 05:03 PM
sc
sc
i wasn't aware there was a difference? I thought it was all together?
Re: cat. converter delete on a 2008 dully with a 6.7 [Re: tjmarcus1] #1512216
10/04/13 11:26 PM
10/04/13 11:26 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Diesel doesn't have a catalytic converter, it had a DPF (Diesel Particulate Filter).
It works to remove soot, ash, and other particulates from the exhaust. A catalytic converter would melt down with all the oil from the diesel fuel.
Re: cat. converter delete on a 2008 dully with a 6.7 [Re: hp383] #1512217
10/04/13 11:33 PM
10/04/13 11:33 PM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
Re: cat. converter delete on a 2008 dully with a 6.7 [Re: hp383] #1512218
10/05/13 11:38 AM
10/05/13 11:38 AM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
sorry but your wrong I had an 04,05 and an 06 and they all had a cat but no dpf now the new ones have both.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: cat. converter delete on a 2008 dully with a 6.7 [Re: dusturbd340W5] #1512219
10/05/13 01:25 PM
10/05/13 01:25 PM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
Are you sure they were cats? I have looked into this and there is a lot of conflicting info. But most agree that sometime in 08 was when the diesel cat was installed.
On diesel bombers forum many of the thought to be cats were either the muffler or resonator in the exhaust.
Converters on a diesel are news to me, my appologies for missinformation. And still not sure how they made that work. Since diesel fuel is such an oily product how do they keep from plugging and melting down the cat? What purpose does it serve? In a gas engine it burns up extra unburt emissions. This doesn't seem like it would work in a diesel engine.
Re: cat. converter delete on a 2008 dully with a 6.7 [Re: hp383] #1512220
10/05/13 01:48 PM
10/05/13 01:48 PM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
Yep, they do have cats on diesels. Along with a bunch of other junk. My 2011 Ram has 5 separate devices in the exhaust. Even some of the earlier trucks had cats if they were on the left coast.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: cat. converter delete on a 2008 dully with a 6.7 [Re: hp383] #1512221
10/05/13 03:58 PM
10/05/13 03:58 PM
San Francisco
dilvoy Offline
dilvoy  Offline
San Francisco
I first saw cat converters on diesels on the Hummer H1 back in 1998. Maybe it was a California thing and other states adopted them at a later time.
Re: cat. converter delete on a 2008 dully with a 6.7 [Re: dilvoy] #1512222
10/06/13 12:02 AM
10/06/13 12:02 AM
sc
sc
thanks guys, but how do I delete it?
Re: cat. converter delete on a 2008 dully with a 6.7 [Re: tjmarcus1] #1512223
10/06/13 12:29 AM
10/06/13 12:29 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Most tuners that deleted them are now out of business ..
I think you can still find them but, expensive ..
EPA
Cracked down hard on DPF delete tuners
Might have trouble finding a Delete pipe for the same reason
although, I'm sure someone will sell you what you need
Re: cat. converter delete on a 2008 dully with a 6.7 [Re: bigdad] #1512224
10/06/13 01:56 AM
10/06/13 01:56 AM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
Check on RaceME12
Re: cat. converter delete on a 2008 dully with a 6.7 [Re: Michael] #1512225
10/06/13 09:15 AM
10/06/13 09:15 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
for my own education, are there sensors or something that can tell if it's installed or not? IT shouldn't be that hard to buy a section of pipe long enough to replace whatever component you're trying to remove.
a trick we do on the Dakota's when deleting the cat is to leave the downstream O2 sensor hooked up electronically, but zip tied to the frame rail so it's reading ambient air. tricks the computer into thinking that the cat is working REALLY well.
**Photobucket sucks**
Re: cat. converter delete on a 2008 dully with a 6.7 [Re: 70Cuda383] #1512226
10/06/13 12:17 PM
10/06/13 12:17 PM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
Yep Tom, there are sensors. They are needed for what is happening at the engine. The delete kits get rid of EGR and the dumping of raw fuel to burn out the filters. If you do the deletes and don't change things downstream, you will set codes.
Re: cat. converter delete on a 2008 dully with a 6.7 [Re: rattler] #1512227
10/06/13 01:07 PM
10/06/13 01:07 PM
West Central Indiana
Mr.Runum Offline
Mr.Runum  Offline
You have to buy a tuner (if you can still get) I went with a Smarty Jr and you have to remove everything at the same time. DPF, EGR Cooler and install the tuner. I did away with the cat, dpr, egr cooler, and the piece on the intake. Turbo back exhaust w/muffler. Did the work myself, the whole 9ydrs was about $1,009.00. the truck will get 22mpg @65mph.
69 RoadRunner 383 4spd coupe, 06 Hemi Daytona Charger, 08 6.7 RAM QC short bed 3/4 4X4
