Easy Undercoating removal method #1511847
10/03/13 12:37 PM
10/03/13 12:37 PM
Arizona
410mopar Offline OP
410mopar  Offline OP
Arizona
Many thanks to "Challenger1". I follow his advise and had all the undercoating removed from my 65 coronet in just 5 hours. I had a mobil steam cleaning guy come and blast it off. I also sprayed gasoline as need. No scraping, no scratches, very easy. He also steamed cleaned the remaining part of the car. Thanks again to "Challender1".
Re: Easy Undercoating removal method [Re: 410mopar] #1511848
10/03/13 01:03 PM
10/03/13 01:03 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
Yep, a good (HOT) steam cleaner works the best. If you don't own one rent one or hire someone with a "ture" steam cleaner.
Re: Easy Undercoating removal method [Re: 410mopar] #1511849
10/03/13 01:09 PM
10/03/13 01:09 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
Is the car on a rotisserie?
Re: Easy Undercoating removal method [Re: 67vertman] #1511850
10/03/13 01:09 PM
10/03/13 01:09 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
So a little gas is all it took to loosen up the stubborn sections?
Re: Easy Undercoating removal method [Re: mopowers] #1511851
10/03/13 01:11 PM
10/03/13 01:11 PM
Canton, Ohio
Crazy68Dart Offline
Crazy68Dart  Offline
Canton, Ohio
My question too. I have another card that I would love to get the undercoating off of. Previous owner had it after-market under coated multiple times and it is everywhere. Non-Mopar so I won't say anything more than that...
383, Hemi 4-Speed, AlterKtion, D60
Re: Easy Undercoating removal method [Re: Crazy68Dart] #1511852
10/03/13 03:22 PM
10/03/13 03:22 PM
Arizona
410mopar Offline OP
410mopar  Offline OP
Arizona
Yes, the car is on a rotisserie (Auto Twirler pro). As he was spraying one area I would spray gasoline on another area. Used about 2 gallons. Only in a few corners was it necessary to manually break the stuff loose.
Re: Easy Undercoating removal method [Re: 410mopar] #1511853
10/03/13 03:50 PM
10/03/13 03:50 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Re: Easy Undercoating removal method [Re: Challenger 1] #1511854
10/04/13 02:15 AM
10/04/13 02:15 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Poor man's rotisserie at this link, if your car is stripped and doesn't weigh much. Looks like if you lift it from each side, this would work.
https://board.moparts.org/ubbthreads/show...amp;Search=true
Re: Easy Undercoating removal method [Re: kentj340] #1511855
10/04/13 10:22 AM
10/04/13 10:22 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Dang, I wish I knew this steam cleaning process sooner. I spent hours under mine heating & scraping the factory & aftermarket undercoating off of my 70' Challenger. I weighed it all when done & was over 50 lbs when done. The end results came out great though.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
