Decent sound system retaining stock radio????? #1511753
10/03/13 11:30 AM
10/03/13 11:30 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Hi!
I am doing a Challenger for a friend and he wants to retain the stock radio, but have a decent sound system where he can plug his Ipod and blast some tunes.
He wants dual speakers on the dash and he also wants dual speakers on the package tray, probably a subwoofer as well.
Is there any way to run all of this thru a stock radio? Does anybody offer stock radio conversions that look stock on the face but pack modern internals?
Or should I just leave the stock radio working thru the center speaker on the dash, and just use an aftermarket radio inside the glovebox????
Re: Decent sound system retaining stock radio????? [Re: domingo] #1511754
10/03/13 11:54 AM
10/03/13 11:54 AM
Andrewh Offline
Andrewh  Offline
http://www.classiccarstereos.com/category/Mopar-Radio.html
kind of pricey imo, but worth it for a restore job.
Re: Decent sound system retaining stock radio????? [Re: Andrewh] #1511755
10/03/13 12:13 PM
10/03/13 12:13 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Still doesnt look stock-! it has an LCD screen!
Re: Decent sound system retaining stock radio????? [Re: domingo] #1511756
10/03/13 12:40 PM
10/03/13 12:40 PM
AL
jglen490 Offline
jglen490  Offline
AL
Dual speakers on the package tray doesn't sound too stock, either! If it's a show car, targeted towards 100% original, then pay the price with a retro radio. If good sound is the goal, then a modern sound system CAN be dash mounted very nicely - with some effort - to go along with package tray rear speakers and properly set up fronts.
Re: Decent sound system retaining stock radio????? [Re: domingo] #1511757
10/03/13 12:47 PM
10/03/13 12:47 PM
near New Haven, CT
fireeng Offline
fireeng  Offline
near New Haven, CT
I bought one of these. They are expensive. There was a 4-6 week wait on them when I ordered but I was able to talk the vendor down $50 bucks when I ordered.
http://www.radiosforoldcars.com/newradio0F.htm
The tuner indicator never worked properly even after sending the radio back 3 times but the radio does look stock, picks up a lot of stations, has decent sound with 45 watts and has RCA jacks for ipod or satellite hook up.
2016 Diesel Ram 3500 Mason Dump
1971 Challenger
2013 Jeep Wrangler
1979 Dodge Ram Power Wagon 400 Mini Pumper
My other car is a Fire Truck.
Re: Decent sound system retaining stock radio????? [Re: fireeng] #1511758
10/03/13 12:54 PM
10/03/13 12:54 PM
near New Haven, CT
fireeng Offline
fireeng  Offline
near New Haven, CT
I think Wards can do what you want.
http://www.wardsclassiccarradiorepair.com/
I didn't have a stock radio to start with, that's why I went the route I did. If you have the stock radio, I think converting that one is the way to go. I also found a speaker for my one speaker dash that had left and right tweeters installed in it so it fit in the stock one speaker space. I forget where I bought that though. I put some decent 6x9s under the slotted package tray for the rears and mine sounds pretty good.
1971 Challenger
2013 Jeep Wrangler
Re: Decent sound system retaining stock radio????? [Re: jglen490] #1511759
10/03/13 12:55 PM
10/03/13 12:55 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Its not a show car targeted to 100% stock....but the dual rear speakers under the perforated package tray are almost invisible unless you stick your head inside the trunk. Now the radio, thats something thats IN YOUR FACE and totally visible.
im just trying to have a stock looking interior at first glance.
Re: Decent sound system retaining stock radio????? [Re: fireeng] #1511760
10/03/13 12:59 PM
10/03/13 12:59 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Re: Decent sound system retaining stock radio????? [Re: domingo] #1511761
10/03/13 01:05 PM
10/03/13 01:05 PM
Canton, Ohio
Crazy68Dart Offline
Crazy68Dart  Offline
Canton, Ohio
Leave the stock radio alone.
Add an amplifier to drive the 6x9s and possible other speakers up front (kick panels) or possibly component speakers hidden somewhere.
The input to the amp could either be a bluetooth adapter that would allow you to stream wirelessly from a device or a hard line connection, something like a cable run from the input side of the amp up front, RCA to mini plug stereo adapter or similar. There are likely iPod specific adapters out there as well, if he is a true apple fanboy.
The bluetooth or mini jack option allows you to use many devices, could stream pandora from cell phone, etc.
383, Hemi 4-Speed, AlterKtion, D60
Re: Decent sound system retaining stock radio????? [Re: jglen490] #1511762
10/03/13 01:07 PM
10/03/13 01:07 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Nobody said anything about sounding stock, in fact it is readily apparent that the object was to NOT sound stock, just look it.
There is a company that will take your stock radio, put new guts in it and add an external jack and USB port (both hidden). But I forget who it was, sorry.
Don't be the exception.
Re: Decent sound system retaining stock radio????? [Re: domingo] #1511763
10/03/13 01:32 PM
10/03/13 01:32 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
'Instrument Specialties'...
Page 39...
Nov '13 MCG...
Re: Decent sound system retaining stock radio????? [Re: Supercuda] #1511764
10/03/13 02:22 PM
10/03/13 02:22 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I think what he meant by "doesn't sound stock" was "that is not a stock appearing installation"
**Photobucket sucks**
Re: Decent sound system retaining stock radio????? [Re: 70Cuda383] #1511765
10/03/13 04:58 PM
10/03/13 04:58 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Ward's is the go to guy around here for radio conversions.
Even the 4X45 watt conversion tunner put inside your stock radio like done by Wards and other places doesn't look stock when you look under the dash because there are many more wires than stock.
This radio was not done by Ward's wish it was.
I have been using it since 2005, it's got some wear already and it quit working a while back. I think I may have touched a speaker wire to ground for a split second moving a front dash mounted speaker around in the dash with the radio on?
After I installed the front speakers it never worked again. I have bench tested it many times. I talked to Greg Ward and one of these days I may do it all over again? It still lights up and tunes, just no sound.
I had the same deal in my 74, conversion radio with 4 speakers, sounded OK.
Then one day it quit...and I found one of the rear speaker wires knocked off by some cargo that got put in the trunk.. I can only assume the same thing happened to that radio? so here's a word of caution, use insulated speaker wire connectors.
Now I like the amp and blue tooth idea more than the conversion radio? Like the sub woofer no matter how small and because I have fallen in love with my I pod. Find myself using it all the time now when I can. It's on my Iphone too which is synced with my new truck.
Re: Decent sound system retaining stock radio????? [Re: domingo] #1511766
10/03/13 09:11 PM
10/03/13 09:11 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
My buddy has a brand x radio delete car. He put a complete system (head unit w/iPod and aux inputs,amp,even hid the antenna!)hid very nicely in the trunk. It drives a pair of nice 6x9's in the package tray. He runs it all with a remote and it sounds very nice. Even with the trunk open it's hard to see, with it closed nobody knows it's there unless he turns it on
Look around at www.crutchfield.com .lots of options
Re: Decent sound system retaining stock radio????? [Re: Dcuda69] #1511767
10/03/13 10:01 PM
10/03/13 10:01 PM
Canton, Ohio
Crazy68Dart Offline
Crazy68Dart  Offline
Canton, Ohio
Exactly. Depends on the kind of guy you are. Want to show off your goods, or hide them? Considering technology, and if you are worried about originality, leave your stock radio and 4x10 (or... use the speaker frame to mount a 6AL box under the dash like I did... lol) alone. Put an entirely different/separate system using new tech components. If you want to drive them with a phone/device there are many options.
Re: Decent sound system retaining stock radio????? [Re: Crazy68Dart] #1511768
10/04/13 01:04 AM
10/04/13 01:04 AM
Farmland, IN
Ludington1 Offline
Ludington1  Offline
Farmland, IN
Greg Ward does great work and could not be more helpful!
Darren
Re: Decent sound system retaining stock radio????? [Re: domingo] #1511769
10/04/13 01:49 PM
10/04/13 01:49 PM
California, USA
filmsurgeon Offline
filmsurgeon  Offline
California, USA
These are sold by several online retailers, including Classic Industries
http://www.ebay.com/itm/1970-74-Mopar-E-Body-AM-FM-Stereo-Reproduction-Radio-/200432802415
