Re: Stamps/Stencils for diff. part marking [Re: 1ol74charger4me] #1510841
10/27/13 11:44 AM
10/27/13 11:44 AM
Il
1ol74charger4me Offline
Il
Updating the list.
Housing, "9-14U". Pig, "9-14".
Housing, "5-12Z". Pig, ?
Housing, "2-16X". Pig, ? SPD 2/26.
Housing, "...1L". Pig, "10-23". Hamtramck. SPD 11/8/68.
Housing, "101G". Pig, ?
Housing, "J128". Pig, ?
Housing, "19U". Pig, ? should be 190, I had went over it with paint pen to get a size picture of it, pig was a 67 and no markings
Final cleaned the rear and found it was in fact a U.
I think there is a correlation between the housing date and the pig date. Maybe same date or close.
Found this while cleaning the housing also. Big surpise. B body+J code engine ?
Re: Stamps/Stencils for diff. part marking [Re: 1ol74charger4me] #1510842
10/27/13 11:46 AM
10/27/13 11:46 AM
Il
Il
before tracing with yellow paint pen
Re: Stamps/Stencils for diff. part marking [Re: 1ol74charger4me] #1510843
10/27/13 11:50 AM
10/27/13 11:50 AM
Il
Il
Hard to see but there is an F on this 70 challenger rear. Only marking found. Its interesting to note that both this and other rear were marked from same position.
Re: Stamps/Stencils for diff. part marking [Re: 1ol74charger4me] #1510844
10/27/13 11:52 AM
10/27/13 11:52 AM
Il
Il
Glad Press and Seal to establish marking pattern.
Re: Stamps/Stencils for diff. part marking [Re: 1ol74charger4me] #1510845
03/17/14 02:36 AM
03/17/14 02:36 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Here's paint daubs and marks on a 1969 Barracuda 8-3/4 axle with 3.23:1, non Sure Grip, made at Hamtramck November 1968.
White paint daub on yoke:
Re: Stamps/Stencils for diff. part marking [Re: kentj340] #1510846
03/17/14 02:40 AM
03/17/14 02:40 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Assembly date of the carrier only, 10/23/68.
Re: Stamps/Stencils for diff. part marking [Re: kentj340] #1510847
03/17/14 02:43 AM
03/17/14 02:43 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
This paint is rust stained but is actually white. There are bars above and below the 23. The SPD of the car was B08, November 8. The actual build date was several days later, because the car arrived at the Houston dealer on November 27. A good chemical rust remover will leave the paint, so I can keep this original stencil as it is under some RPM wax.
Re: Stamps/Stencils for diff. part marking [Re: kentj340] #1510848
03/17/14 03:03 AM
03/17/14 03:03 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
The yellow unit assembly date, L1xxx, is on the bottom of the driver side. The last three numbers of the assembly part number, 565, are seen just above on the front of the housing. The yellow 565 is upside down when the axle is on the car.
Re: Stamps/Stencils for diff. part marking [Re: kentj340] #1510849
03/17/14 03:13 AM
03/17/14 03:13 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
The yellow unit assembly date, according to others, is usually the same date as the carrier date or one or two days after. Nobody seems to know what the alpha means. This might be L10 23 or L10 24? Looks like the 1 and L are upside down to each other?
Re: Stamps/Stencils for diff. part marking [Re: kentj340] #1510850
03/17/14 03:17 AM
03/17/14 03:17 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Another
Re: Stamps/Stencils for diff. part marking [Re: kentj340] #1510851
03/17/14 03:40 AM
03/17/14 03:40 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Here's the upside down yellow assembly number 565 with the driver side spring perch below right. This is the same number on my broadcast sheet under AXLE. AFAIK the only places you can get this part number are from the axle, from the build sheet, or copy somebody else's car that has the exact same axle (year, size, ratio, w or w/o Sure Grip, brakes) in the same kind of car with the same engine and transmission. Note there is more paint at the edges of the numbers. There is an intentional or unintentional bar under a 5.
Re: Stamps/Stencils for diff. part marking [Re: kentj340] #1510852
03/17/14 03:46 AM
03/17/14 03:46 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Yellow paint daub on front passenger side.
Re: Stamps/Stencils for diff. part marking [Re: kentj340] #1510853
03/17/14 03:51 AM
03/17/14 03:51 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
These photos don't show it, but there was spray paint overspray inside the housing.
Re: Stamps/Stencils for diff. part marking [Re: kentj340] #1510854
03/17/14 04:04 AM
03/17/14 04:04 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Almost gone, but here's another round yellow paint daub of the same size at the front of the passenger side spring perch. Couldn't find one on the driver side.
Re: Stamps/Stencils for diff. part marking [Re: kentj340] #1510855
03/17/14 04:13 AM
03/17/14 04:13 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
My yellow A was done by a pro and looks better than yours. The A is right side up when installed. A white paint stick X is above.
Re: Stamps/Stencils for diff. part marking [Re: kentj340] #1510856
03/17/14 04:22 AM
03/17/14 04:22 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Here's the white X above the A. This mark was made with a paint stick, not a lumber crayon.
Re: Stamps/Stencils for diff. part marking [Re: kentj340] #1510857
03/17/14 05:12 AM
03/17/14 05:12 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
One sloppy blue paint daub on the underside of the pig apparently made with a 2" wide or so brush. This one blue daub means 3.23 ratio and small stem size, according to the chart. This 3.23 axle is for a 340 4-speed. The big stems must have been for big blocks.
Re: Stamps/Stencils for diff. part marking [Re: kentj340] #1510858
03/17/14 05:22 AM
03/17/14 05:22 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Last one for this 69 Barracuda 8-3/4, 3.23, non Sure Grip. A scrawled 8 on the pig. There's a small amount of a different shade of blue splashed on the top side of the pig. I'll keep the marks on the pig as they are. The housing will get repainted semi gloss black after the rust pits are filled in, so the housing will get re-daubed.
